For A LOT MORE photos and information click here: http://www.totalmotorcycle.com/motorcyc ... -SR400.htm
2015 Yamaha SR400 on the Total Motorcycle Cool Wall
Everything old is new again...
The new SR400 is a legendary classic that’s a kick to ride. With it's retro 1970s styling and one of the best performing 399cc air-cooled engines, the SR400 embodies the true meaning of the saying “Everything old is new again.” Jump on, give the kickstarter a stab, and you will be on your way.
Unlike some retro bikes that are modern interpretations of older designs, the SR400 is an authentic living classic which has been
constructed to virtually the same specification as the original model. With its air-cooled engine and twin-shock chassis, this timeless big single represents a return to motorcycling's core values.
Start with a 399cc air-cooled 4-stroke single-cylinder engine with one intake valve, one exhaust valve, and one exhaust pipe – timeless simplicity. Add a slim chassis with a natural riding position that delivers sporty relaxed handling. What you get is an authentic design and pure mechanical beauty that makes the SR400 a true classic, from any angle.
The Yamaha SR400 has stood the test of time like no other model. It represents everything that is good about motorcycling. And the same core values that appealed to yesterday's motorcyclists are ready to inspire today's generation of riders who appreciate retro style with proven technology like fuel injection, high-tensile steel semi-double cradle frame that doubles up as an oil tank, plush suspension, and an easy-to-start air-cooled 4-stroke single-cylinder engine.
The big single has always held a special place in the hearts of motorcyclists but kick starting a big single can be a challenge. Yamaha engineers have made kick starting the SR400 a breeze using a decompressor and piston position indicator.
This timeless retro just oozes charm and authenticity wherever you look. And as the basis for creating your own café racer, bobber or street scrambler, the SR400 offers endless possibilities.
2015 Yamaha SR400 - Totalmotorcycle.com USA Specifications/Technical Details
US MSRP Price: $5,990 (Liquid Graphite) Available from May 2014
UK/European MSRP Price: £9,795.00 GBP (On The Road).
Engine
Type 399cc, air-cooled SOHC, 2-valve
Bore x Stroke 87.0 x 62.7mm
Compression Ratio 8.5:1
Fuel Delivery Fuel Injection
Ignition TCI: Transistor Controlled Ignition
(totalmotorcycle.com) Transmission 5 speed; multiplate wet clutch
Final Drive Chain
Chassis
Suspension / Front Telescopic; 5.9-in travel
Suspension / Rear Swingarm; 4.1-in travel
Brakes / Front Hydraulic disc brake, 268mm
Brakes / Rear 150mm drum
Tires / Front 90/100-18M/C 54S
Tires / Rear 110/90-18M/C 61S
Dimensions (totalmotorcycle.com)
Length 82.1 in
Width 29.5 in
Height 43.1 in
Seat Height 30.9 in
Wheelbase 55.5 in
Rake (Caster Angle) 27.7º
Trail 4.4 in
Fuel Capacity 3.2 gal
Fuel Economy** 66.2 mpg (totalmotorcycle.com)
Wet Weight*** 384 lb
