For MORE information and Photos click here: http://www.totalmotorcycle.com/motorcyc ... -R-ABS.htm
UNLEASH THE BEAST...
In the form of the KTM 1290 SUPER DUKE R, KTM has crowned its legendary Naked Bike model range with a machine that redefines the term 'Streetfighter'. One look at its impressive performance data and aggressive design is enough to see that the 1290 R is the most extreme Super Duke ever. Thanks to unbeatable performance in conjunction with the versatility provided by the adjustable riding modes and PowerParts setups, pure riding pleasure is pre-programmed - from the racetrack to the city and everywhere in between. The new KTM 1290 SUPER DUKE R perfectly embodies the KTM philosophy: endless power, highest precision, perfect ergonomics, finest ingredients, not a gram too many, simply "Ready to Race"! The KTM 1290 SUPER DUKE R – high-tech in an aggressive design with unprecedented functionality and razor-sharp sportiness reduced to the essentials. The new KTM 1290 SUPER DUKE R transforms optimum performance with maximum safety into ultimate riding pleasure.
2014 KTM 1290 Super Duke R ABS Totalmotorcycle.com Key Features
Big boss
From zero to 200 km/h (124 mph) in 7.2 seconds – with low fuel consumption and a 15,000 km service interval
What happens when KTM packs the attributes of the proven 75-degree V-twin into 1.3 litres of displacement? The result is an extremely lightweight, elemental engine filled with state-of-the-art racing technology, yet still even more sophisticated, durable and cultivated than ever. 132 kW (180 hp) peak power, 144 Nm maximum torque with 100 Nm as early as 2500 rpm – could there be better guarantees for explosive propulsion whatever the revs?
2014 KTM 1290 Super Duke R ABS - Totalmotorcycle.com USA Specifications/Technical Details
US MSRP Price: $16,999 USD
Canadian MSRP Price: $19,499 CDN
ENGINE
Design 2-cylinder, 4-stroke, spark-ignition engine, 75° V arrangement, liquid-cooled
Displacement 1,301 cm³
Bore 108 mm
Stroke 71 mm
Starting aid Electric starter
Performance 132 kW (180 PS)
Engine lubrication Forced oil lubrication with 3 rotor pumps
Primary gear ratio 40:79
Secondary gear ratio 17:38
Cooling system Liquid cooling system, continuous circulation of cooling liquid with water pump
Clutch PASC™ anti-hopping clutch/ hydraulically operated
Ignition system Contactless, controlled, fully electronic ignition system with digital ignition timing adjustment
CHASSIS
Frame Tubular space frame made from chrome molybdenum steel, powder-coated
Fork WP Suspension Up Side Down
Shock absorber WP Suspension Monoshock
Suspension travel front 125 mm
Suspension travel rear 156 mm
Brake system front Twin-disc brake with radially mounted four-piston brake calipers
Brake system rear Single-disc brake with two-piston brake caliper; fixed brake disc
Brake discs - diameter front 320 mm
Brake discs - diameter rear 240 mm
Chain 5/8 x 5/16" X Ring
Steering head angle 65.1°
Wheel base 1,482±15 mm
Ground clearance (unloaded) 140 mm
Seat height (unloaded) 835 mm
Total fuel tank capacity approx. 18 l
Unleaded premium fuel (95 RON)
Weight without fuel approx. 189 kg
