For MORE information and Photos click here: http://www.totalmotorcycle.com/photos/2 ... ke-999.htm
The Ducati 749 Testastretta and 999 Testastretta are the most advanced, highest performance, twin-cylinder motorcycles ever produced at our Bologna, Italy factory. They epitomize the racing history of Ducati and represent the evolution of a formula that has dominated Superbike racing for over a decade. This year’s Superbike family includes seven models: the 749 Dark, 749, 749S, 749R, 999, 999S and 999R.
Two years after the launch of the latest Superbike models, Ducati decided the time had come to incorporate in our production models the features of our race machines that make them unbeatable on tracks around the world.
In motion even when others are at rest. Quicker and sexier than ever, these are real race machines that epitomize the best of Ducati’s high performance tradition.
2005 Ducati Superbike 999 Specs on http://www.totalmotorcycle.com
Engine/Drivetrain
Type L-twin cylinder, 4 valves per cylinder Testastretta Desmodromic; liquid cooled
Displacement 998 cc
BorexStroke 100 x 63.5 mm
Compression Ratio 11.4:1
Power 103 kw - 140 hp @ 9750 rpm
Torque 11.1 kgm @ 8000 rpm
Fuel injection Marelli electronic fuel injection, 54 mm throttle body
Exhaust Single steel muffler with catalytic converter
Emissions Euro2
TRASMISSION
Gearbox 6 speed
Ratios 1st 37/15, 2nd 30/17, 3rd 28/20, 4th 26/22, 5th 24/23, 6th 23/24
Primary drive Straight cut gears; ratio 1.84
Final drive Chain; Front sprocket 15; Rear sprocket 36
Clutch Dry multiplate with hydraulic control
Chassis/Suspension
Frame Tubular steel trellis
Wheelbase 1420 mm / 55.9 in
Rake 23.5° - 24.5°
Front suspension Showa 43 mm upside-down fully adjustable fork with TiN surface treatment
Front wheel travel 125 mm / 4.9 in
Front brake 2 x 320 mm semi-floating discs, 4-piston 4-pad caliper
Front wheel Y-shaped 5-spoke light alloy 3.50 x 17
Front tyre 120/70 ZR 17
Rear suspension Progressive linkage with fully adjustable Showa monoshock
Rear wheel travel 128 mm / 5 in
Rear brake 240 mm disc, 2-piston caliper
Rear wheel Y-shaped 5-spoke light alloy 5.50 x 17
Rear tyre 190/50 ZR 17
Fuel tank capacity 15.5 L / 4.1 US gal (includes 3 L / 0.8 US gal reserve)
Weight * 186 kg / 410 lbs
Seat height 780 mm / 30.7 in
Instruments Speedometer, rev counter, high beam indicator, turn signals, oil pressure warning light, low fuel warning light, neutral light, water temperature, immobilizer system, http://www.totalmotorcycle.com
Warranty 2 years unlimited mileage
Tank Colours Red, glossy black (for two-seat only)
Frame and Wheel colours Red, black (for two-seat with yellow tank only)
Versions One or Two seats
* = The weight includes battery, lubricants and, where applicable, cooling liquid.
Additional Features
New for 2004 Two years after the "red-volution", all the models in Ducati's Superbike family, in both engine sizes, have been dramatically improved. Updates have involved not just restyling but a series of major improvements to chassis and engine aimed at bringing the 749 and 999 closer still to Ducati's ultimate sports motorcycle concept, making them meaner, faster and more competitive than ever. http://www.totalmotorcycle.com
