For MORE information and Photos click here: http://www.totalmotorcycle.com/motorcyc ... ABS-SE.htm and http://www.totalmotorcycle.com/motorcyc ... enture.htm in the USA
2-up adventure touring....
The spirit of adventure beckons you to new destinations. To new sights, sounds and sensations. The V-Strom 650 ABS is built to get you there with more enjoyment and excitement, in greater comfort. Time for real adventures.
The V-Strom 650 ABS SE builds on the comfort, flexibility and performance of the standard model with Touring Side Cases and Top Case. This unrivaled combination of performance, specifications and value provide what's needed for high mileage, two-up adventure touring.
*The ABS is a supplemental device for brake operation, not a device for shortening stopping distance. Always remember to reduce speed sufficiently before approaching curves.
2015 Suzuki V-Strom 650 ABS Adventure http://www.Totalmotorcycle.com Features and Benefits
ENGINE FEATURES
645cc V-Twin engine features broad torque delivery, signature V-Twin power pulses and sporty quick-revving high rpm range power surges for full-range riding enjoyment. An efficient engine design delivers high mileage and class-leading riding range.
A high-speed 32-bit ECU controls Suzuki Dual Throttle Valve (SDTV) system, contributing to enhanced low-to-mid rpm range torque, a linear throttle response and lower emissions.
Twin iridium spark plugs for each cylinder for better spark strength and combustion efficiency contributing to increased power, a more linear throttle response, easier engine start-up and a more stable idle.
2015 Suzuki V-Strom 650 ABS SE - http://www.Totalmotorcycle.com Specifications/Technical Details
Canada MSRP Price: $10199 CDN
US MSRP Price: $10049 USD
ENGINE
Type 4-stroke, 2-cylinder, liquid-cooled, DOHC, 90degree V-Twin
Displacement 645 cm3 (39.4 cu. In)
Bore x Stroke 81.0 mm X 62.6 mm (3.189 in X 2.465 in)
Compression Ratio 11.2 : 1
Transmission 6-speed constant mesh
CHASSIS
Overall Length 2290 mm (90.2 in)
Overall Width 835 mm (32.9 in)
Overall Height 1405 mm (55.4 in)
Wheelbase 1560 mm (61.4 in)
Ground Clearance 175 mm (6.9 in)
Seat Height 835mm (32.9 in)
Curb Mass 214 kg
Suspension Front Telescopic, coil Spring, oil damped
Suspension Rear Link type, coil spring, oil damped
Brakes Front Disc, twin
Brakes Rear Disc
Tires Front 110/80R19M/C 59H, tubeless
Tires Rear 150/70R17M/C 69H, tubeless
Ignition Type Electronic ignition (Transistorized)
Fuel Tank 20.0 L (5.3 US gal)
