For MORE information and Photos click here: http://www.totalmotorcycle.com/motorcyc ... Tenere.htm
The Ultimate Transcontinental Adventurer...
The 2015 Yamaha Super Tenere has everything you need to conquer the world: powerful, ultra compact 1199cc parallel inline twin; electric cruise control; 6 speed transmission; YCC-T and 2 position Drive Mode; traction control; advanced ABS brakes and adjustable seat. Pack your passport and hunger for worldwide adventure!
The Super Ténéré comes with a prestigious lineage of success at the famous Paris to Dakar Rally. In fact, Yamaha won the first ever event in 1978 and followed that up with 8 other victories at the world's most gruelling rally.
2015 Yamaha Super Tenere http://www.Totalmotorcycle.com Key Features
/// Key Highlights
• Compact, 1199cc parallel twin featuring a unique 270° crank and dual balancer shafts
• Wide-ratio 6-speed transmission
• Yamaha's Chip Controlled Throttle with D-Modes (2-position)
• Cruise control system
• Adjustable KYB suspension front & rear
• Multi-function meter with DOT Matrix liquid crystal display and GPS
holder bar • No tools required, 4-position adjustable windshield
• Aluminum tapered handlebar and compact LED signals
/// Power
The Super Ténéré is built for adventure, with an exceptionally narrow and compact 1199cc parallel twin using a unique 270° crank for excellent torque and traction. Engine mass is kept low for surprisingly light, agile handling. Its wide-ratio 6-speed transmission has the right gear, whether on the open highway or off-road. Your adventure begins here.
/// Performance
Whether touring across North America, carving up a twisty road or exploring a deserted fire road, the Super Ténéré is guaranteed to provide the highest levels of comfort, convenience and performance that riders have come to expect from Yamaha.
2015 Yamaha Super Tenere - http://www.Totalmotorcycle.com USA Specifications/Technical Details
US MSRP Price: $15,090 - Candy Red
$15,090 - Matte Silver
Canada MSRP Price: $16,599 CDN
Engine
Engine Type 1199cc, liquid-cooled, 4-stroke 2-cylinder DOHC
Bore x Stroke 98.0 x 79.5mm
Compression Ratio 11.0:1
Fuel Delivery Fuel Injection with YCC-T
Ignition TCI: Transistor Controlled Ignition
Transmission Constant mesh, 6-speed
Final Drive Shaft
Chassis
Suspension / Front Telescopic fork, 43mm tube, adjustable preload, compression and rebound damping, 7.5-in travel
Suspension / Rear Monoshock, adjustable preload and rebound damping, 7.5-in of travel
Brakes / Front Dual 310mm hydraulic disc, ABS/Unified Brake System
Brakes / Rear 282mm single disc
Tires / Front 110/80R19M/C 59V
Tires / Rear 150/70R17M/C 69V
Dimensions
Length 88.8 in
Width 38.6 in
Height 55.5 in
Seat Height 33.3 or 34.3 in
Wheelbase 60.6 in
Rake (Caster Angle) 28.0°
Fuel Capacity 6.1 gal
Fuel Economy** 43 mpg
Wet Weight*** 575 lb
