For MORE information and Photos click here: http://www.totalmotorcycle.com/motorcyc ... 0-Camo.htm
Adventure Unlimited...
The rugged and tough 2016 Kawasaki KLR650 motorcycle is built for adventure. Riders on pavement or off-road will benefit from the KLR650 motorcycle’s phenomenal fuel range and dual-purpose capabilities.
The rugged and tough 2016 Kawasaki KLR™650 motorcycle is built for adventure. It will take you where you want to go in comfort, year-round, and with a budget-conscious package. Riders on pavement or off-highway will benefit from the KLR650 motorcycle’s phenomenal fuel range from its 6.1-gallon tank. In fact, this innovator of the dual-purpose category will take riders practically anywhere they’ve dreamed of visiting.
The adjustable, long-travel 41mm telescopic front fork and Uni-Trak® rear suspension contribute to the superb balance of the dependable KLR650, providing excellent composure when ridden on canyon roads. It also offers significant bottoming resistance when ridden over technical off-highway terrain.
The multi-contoured, dimpled seat is narrow at the front for an easy reach to the ground, and wider towards the rear to enhance rider maneuverability and boost long-range comfort.
2016 Kawasaki KLR650 Camo http://www.Totalmotorcycle.com Key Features
• NEW 2016 Matrix Camo Gray color scheme available
• Torquey and durable 651cc four-stroke single-cylinder engine
• Long-travel 41mm telescopic fork
• Adjustable Uni-Trak® rear suspension
• Multi-contoured seat with dimpled cover
• 6.1-gallon fuel tank for long-range adventure touring
• Wind protection to reduce wind buffeting
• Sturdy rear cargo rack
COLOR OPTIONS
New for the 2016 Kawasaki KLR650 motorcycle is the inclusion of Matrix Camo Gray
2016 Kawasaki KLR650 Camo - http://www.Totalmotorcycle.com USA Specifications/Technical Details
US MSRP Price: $6899 USD
Power
Engine
4-stroke, 1-cylinder, DOHC, water-cooled
Displacement
651cc
Bore x Stroke
100.0 x 83.0mm
Compression ratio
9.8:1
Fuel System
Keihin CVK40
Ignition
Electric CDI
Transmission
5-speed
Final Drive
Sealed chain
Performance
Front Suspension / Wheel Travel
41mm telescopic fork/7.9 in
Rear Suspension / Wheel Travel
Uni-Trak® single-shock system with 5-way preload and stepless rebound damping/7.3 in
Front Tire
90/90x21
Rear Tire
130/80x17
Front Brakes
Single 254mm petal-type disc, 2-piston caliper
Rear Brakes
Single 212mm disc, single-piston caliper
Details
Frame Type
Semi-double cradle, high-tensile steel
Rake/Trail
28.0°/4.4 in
Overall Length
90.4 in
Overall Width
37.8 in
Overall Height
53.1 in
Ground Clearance
8.3 in
Seat Height
35.0 in
Curb Weight
432.0 lb**
Fuel Capacity
6.1 gal
Wheelbase
58.3 in
Color Choices
Matrix Camo Gray
Warranty
12 Month Limited Warranty
Kawasaki Protection Plus™ (optional)
12, 24, 36 or 48 months
