2016 Norton Dominator SS - Coolness Factor = 82.6%
Your Coolness Factor of the 2016 Norton Dominator SS is:
View results
2016 Norton Dominator SS on the Total Motorcycle Cool Wall
For MORE information and Photos click here: http://www.totalmotorcycle.com/motorcyc ... tor-SS.htm
One small step for man, one giant leap for Norton...
The 2016 Norton Dominator SS marks a significant step for Norton as it expands it’s model range beyond the successful Commando 961 platform.
All Dominator SS models are hand built here at the Norton factory within the grounds of Donington Hall. They feature the famous ‘featherbed’ styled chassis and the wonderfully hand crafted aluminium fuel tank. These components are all hand made on site by our skilled fabricators. Just a few of the components that make the Dominator SS a very special motorcycle indeed.
The proper English Roadster
2016 Norton Dominator SS http://www.Totalmotorcycle.com Key Features
Norton launch all new Dominator SS
All new Dominator SS. A fully homologated road going bike developed out of the hugely successful Domiracer. The Dominator SS will be privately previewed at an exclusive evening to be held at Donington Hall at the end of January 2015.
Initially only 50 Dominator SS bikes are to be launched in the UK in 2015. The Dominator will be an ongoing model for Norton and launched with the SS limited edition. The Dominator SS will be launched throughout the world later in 2015.
2016 Norton Dominator SS - http://www.Totalmotorcycle.com USA Specifications/Technical Details
US MSRP Price: $ See dealer for pricing in USD
Canada MSRP Price: $ See dealer for pricing in CDN
Europe/UK MSRP Price: £19950 GBP (On The Road inc 20% Vat)
Engine
Engine type: In house developed parallel twin with dry sump lubrication. Black with polished covers. Compression ratio: 10.1:1
Displacement: 961cc Power: 80PS at 6500RPM
Cooling system: Air/Oil Torque: 90Nm at 5200RPM
Valve actuation: Push rod, hydraulic roller lifter, 2 valves per cylinder Exhaust: Stainless steel
Bore x Stroke: 88mm x 79mm Ignition: Crank fired electronic fuel injection & 2 way catalytic converters. Euro 3 compliant.
Transmission
Gear box: 5-Speed, Constant Mesh
Final drive: 525 O-ring chain
Clutch: Wet multi-plate
Dimensions
Wheelbase: 1450mm (55.9") Front tyre: 120/70 x 17"
Rake: 24.0° Rear tyre: 180/55 x 17"
Trail: 99mm (3.9") Front wheel travel: 115mm (4.53")
Front wheel: 36 spoke 3.5" x 17" Black Rim Rear wheel travel: 100mm (3.94")
Rear wheel: 40 spoke 5.5" x 17" Black Rim Seat height: 813mm (23")
Suspension
Front suspension: 43mm Black-line Ohlins USD - adjustable preload, compression & rebound damping
Rear suspension: Ohlins TTX 36 mono shock with remote reservoir - adjustable ride height, preload and compression
Brakes
Front Brakes: Full Brembo system, twin Brembo 320mm fully-floating high carbon stainless steel discs & Brembo 4 piston "Mono bloc" radially mounted calipers. Brembo radial front brake master cylinder with remote reservoir.
Rear Brakes: Full Brembo system, single Brembo 220mm disc & Brembo 2 piston calliper. Brembo rear brake master cylinder
Clutch: Brembo radial hydraulic clutch master cylinder with remote reservoir and Brembo slave cylinder
Performance
Power: 80PS @ 6500rpm
Torque: 90Nm @ 5200rpm
Electronics & Controls
Charging system: 300 watt hi-output charging system
Instrumentation: Norton electronic analogue speedo and tachometer
Starting system: Electric push button start
Colour Options
Titanium Grey with Black Pinstripe
ceemes
Real Name: a big secret
Re: This Week: 2016 Norton Dominator SS
#2 Unread post by ceemes »
All I can say is: Image
ceemes wrote:All I can say is: Image
LOL, ok, that's funny!!
:laughing:
I voted: Awesome
I really love the Norton styling and the quality of the bikes. At a bike night, I'd definitely be eyeing it up. Would I buy one? Yes, but the prices they are asking for any of their models are at least $10,000 more than another competitor! That's like twice the price! Could be why Norton really isn't expanding much or selling many bikes, especially in a time of economic woes.
So, yes, it's Awesomely cool in many areas. I'd love to own and ride one no question.
£19950 GBP = $39,450 CAD at time of writing so the price? That's a fail.
Featured: February 12th - February 19th 2016
Motorcycle Cool Wall discussion: viewtopic.php?f=61&t=52623
Total Motorcycle model page: http://www.totalmotorcycle.com/motorcyc ... tor-SS.htm
Awesome (3 points) 65% [ 15 ]
Cool (2 points) 22% [ 5 ]
Uncool (1 point) 9% [ 2 ]
Fail (0 point) 4% [ 1 ]
Total votes: 23
= a Coolwall Factor of 82.6%
Notes: If looks could kill. Then this bike would be First Degree. The only issue, is, can you afford it?
[/i]Get excited as the next TMW Cool Wall bike for 2016 is now up for voting and discussion, have fun!
