For MORE information and Photos click here: http://www.totalmotorcycle.com/motorcyc ... Octane.htm
POWER TO BURN...
Take a big motor, put it into a lightweight chassis, then delete any creature comforts or other unnecessary accessories. What’s left is just what you need to go very fast, and nothing else. This is the formula for the Modern American Musclebike.
Victory Octane: the Modern American Musclebike
Every high-octane horsepower enthusiast is familiar with the muscle car formula: take a big motor, insert it into a lightweight chassis then remove any creature comforts or other unnecessary accessories.
What's left is just what you need to go very fast and nothing else.
The all-new Victory Octane is the two-wheeled expression of that concept with a modern twist.
This is raw adrenaline that rules the streets. A 1200cc, liquid-cooled V-twin -Victory's first-ever liquid-cooled engine - utilises dual overhead cams and four-valve heads to rev beyond 8000 rpm and put down 104 horsepower.
That's more horsepower than in any production Victory motorcycle ever built.
No surprise then that Octane is also the quickest Victory down the quarter-mile and the fastest from 0-60 mph too. And with a price starting from €12,950, Octane runs in a class of its own.
A stiff and light cast-aluminium frame transmits every last one of those horsepower directly to the asphalt. Sharp steering geometry, a tight 1578mm (62.1 in) wheelbase and 32° of available lean angle deliver agility previously unknown to American V-twin motorcycles.
Muscular styling cuts an undeniably modern profile and a sportsbike-inspired bullet cowl improves airflow over the rider at the triple-digit speeds that Octane is built to achieve.
The first hundred customers (including pre-orders) will be given a special engine cover with the Project 156 logo on it.
MODERN AMERICAN MUSCLE - A NEW VISION FOR AMERICAN MOTORCYCLES
Victory Octane http://www.Totalmotorcycle.com Features and Benefits
A RACE-BRED POWERTRAIN
Developed from the Project 156 prototype that was tested at the most demanding racing event in the world-the Pikes Peak International Hill Climb™-the 60-degree V-twin features a short-stroke just like the Project 156 racer to allow higher engine rpm and more horsepower and a quick-revving engine more like a sportsbike than any traditional American V-Twin. An electronically metered 60mm throttle body feeds high-flow four-valve heads (operated by dual overhead cams) and liquid cooling quenches the heat generated by 104 horsepower and 99 Nm of tyre-shredding torque. Geared short for quicker acceleration, Octane can sprint down the quarter-mile in 12 seconds and rush from 0-60 mph in less than four seconds. With the heart of a racer, Octane has power to burn.
Based on the Project 156 racer that competed at the Pikes Peak Hill Climb, Octane's 1200cc V-twin uses 4-valve heads, dual overhead cams, and liquid cooling to make 104 horsepower. Geared for acceleration, Octane™ can run the quarter mile in 12 seconds and hit 60 mph in under four seconds.
2017 Victory Octane - http://www.Totalmotorcycle.com USA Specifications/Technical Details
US MSRP Price: $10,499 USD
Canada MSRP Price: $12,499 CDN
Dry Weight 528 lb. (240 kg)
Displacement 1179cc
ENGINE & DRIVETRAIN
Transmission/Final Drive 6-speed/belt
Exhaust Dual slash-cut mufflers with common volume
Fuel System Sequential Fuel Injection with single 60mm throttle body
Compression Ratio 10.8:1
Horsepower (HP) 104 HP @ 8000 RPM
Valve Train DOHC, 4 valves per cylinder
Torque 76 FT-LBS @ 6000 RPM
Final Drive Ration 2.536 : 1
Bore x Stroke (mm) 101.0 x 73.6mm
Engine Type Liquid-cooled 60° V-twin
Suspension
Rear Suspension Twin shocks with dual-rate springs, adjustable preload; 3.0-in. travel
Front Suspension 41mm damper-tube forks with dual-rate springs; 4.7-in. travel
Drivetrain
Clutch Type Wet, multi-plate
Brakes
Rear Brakes Single-piston
Front Brakes Dual piston caliper, 298mm disc
Brake System Type Conventional
Tires / Wheels
Front Tires 130/70-18 63H
Rear Wheel 17 X 4.5-in. cast 10-spoke
Front Wheel 18 X 3.5-in. cast, 10-spoke
Rear Tires 160/70-17 76H
DIMENSIONS
Seat Height 25.9 in. / 658 mm
Wheelbase 62.1 in. / 1578mm
Rake/Trail 29.0°/ 5.1 in. / 130mm
Fuel Capacity (Litres) 3.4 gal. / 12.9 LTR
Overall Vehicle Length 90.9 in. / 2286mm
Lean Angle 32 degrees
Features
Colors (Base) Matte Super Steel Gray
