For MORE information and Photos click here: http://www.totalmotorcycle.com/motorcyc ... -Ultra.htm
A ride that could make a continent feel too small...
If your dream is to go big, this could be the one for you. The Road Glide® Ultra motorcycle combines the most wind-cheating fairing ever devised with the full complement of Harley-Davidson Project RUSHMORE touring features. You get a Tour-Pak® luggage carrier and saddlebags that open with one hand. The top of the line Project RUSHMORE infotainment system. A Twin Cooled Twin Cam 103™ engine. And mind-blowingly comfortable ride for your passenger. All built around the aggressive look of the Road Glide. Call the house sitter.
New for 2016, this one will roll out of the factory doors and never stop until it catches the horizon. Experience world-class aero comfort and BOOM!™ Box 6.5 GT Audio in our new ultimate mile-eater.
Harley-Davidson Touring bikes, infused with enhanced style, outstanding aerodynamics and optimized touring ergonomics for rider and passenger– the full influence of the customer-led Project RUSHMORE product-development effort. Propelled by the unrelenting performance of the Twin-Cooled™ High Output Twin Cam 103™ powertrain, these motorcycles will exceed the expectations of the most demanding touring motorcyclist.
2016 Harley-Davidson Touring Road Glide Ultra http://www.Totalmotorcycle.com Key Features
With its sleek profile and touring essentials, the all-new Road Glide® Ultra model is back to let riders pile up the miles in high style. This fixed-fairing, ultra-cool bagger offers riders and their passengers the ultimate in wind protection and long-haul conveniences along with all the features of Project RUSHMORE.
New model for 2016
2016 Harley-Davidson Touring Road Glide Ultra - http://www.Totalmotorcycle.com USA Specifications/Technical Details
US MSRP Price: Starting from $25699 USD
Canada MSRP Price: Starting from $29799 CDN
PRICING 6
Vivid Black $25,699
Color Option $26,299
Two-Tone Option $26,799
Custom Color Option $26,999
Security Option Standard
ABS Option Standard
Cruise Control Option Standard
Premium Radio Option Standard
California Emissions $200
Freight $435
DIMENSIONS
Length 102.2 in.
Seat Height, Laden 7 28.4 in.
Seat Height, Unladen 7 29.7 in.
Ground Clearance 4.7 in.
Rake (steering head) (deg) 26
Trail 6.7 in.
Wheelbase 64 in.
Tires, Front Specification BW 130/80B17 65H
Tires, Rear Specification BW 180/65B16 81H
Fuel Capacity 6 gal.
Oil Capacity (w/filter) 4 qt.
Weight, As Shipped 881 lb.
Weight, In Running Order 916 lb.
Luggage Capacity -Volume 4.7 cu ft
Weight:
• As Shipped 881 lbs. (400 kg)
• In Running Order 916 lbs. (415 kg), 920 lbs. (417 kg) (CAN)
• Gross Vehicle Weight Rating 1360 lbs. (617 kg)
• Gross Axle Weight Rating
• Front 500 lbs. (227 kg)
• Rear 927 lbs. (420 kg)
ENGINE
Engine 1 Twin-Cooled™ High Output Twin Cam 103™
Bore 3.875 in.
Stroke 4.374 in.
Displacement 103.1 cu in
Compression Ratio 10.1
Fuel System 3 Electronic Sequential Port Fuel Injection (ESPFI)
DRIVETRAIN
Primary Drive Chain, 34/46 ratio
Gear Ratios (overall) 1st 9.593
Gear Ratios (overall) 2nd 6.65
Gear Ratios (overall) 3rd 4.938
Gear Ratios (overall) 4th 4.0
Gear Ratios (overall) 5th 3.407
Gear Ratios (overall) 6th 2.875
CHASSIS
Exhaust Chrome dual exhaust with 4 in. touring mufflers and touring muffler shields
Wheels, Front Type 9 Impeller Cast Aluminum
Wheels, Rear Type Impeller Cast Aluminum
Brakes, Caliper Type 32 mm, 4-piston fixed front and rear
PERFORMANCE
Engine Torque Testing Method J1349
Engine Torque 2 105.5 ft-lb
Engine Torque (rpm) 3,750
Lean Angle, Right (deg.) 31.9
Lean Angle, Left (deg.) 31.8
Fuel Economy: Combined City/Hwy 5 42 mpg
ELECTRIC
Lights (as per country regulation), Indicator Lamps 8 High beam, neutral, running lights, turn signals, low oil pressure, engine diagnostics, cruise control, speakers, accessory, security system, 6-speed, low fuel warning, ABS.
