For MORE information and Photos click here: http://www.totalmotorcycle.com/motorcyc ... -KX110.htm
FUN FOR THE FAMILY...
Whether you use it as a starter bike for your kids, in-the-pits transportation or for mischievous mini-moto action, the KLX110/110L are versatile off-road machines that the whole family can enjoy. You have the option to choose the best t with the 26.8-inch seat height of the KLX110 or the taller 28.7-inch seat height of the KLX110L.
The KLX110 motorcycle is perfect for a younger rider’s first experience in the dirt. A high-tensile steel frame, 30mm telescopic fork, and single rear shock provide easy handling and maximum longevity. It also incorporates an automatic centrifugal clutch system that allows easy shifting through the gears, helping the rider maintain focus on the terrain and to make the most of the 112cc single-cylinder, four-stroke engine.
There’s an electric start for new riders, with an “off” switch right alongside it. The start button is located on the left-hand grip to allow throttle use during start-up, and traditional kickstarter as a back up.
Stepping up to the KLX110L motorcycle, it offers a natural progression as a rider grows in stature and experience. The bike has a taller seat height (28.7” compared to 26.8” for the KLX110), longer suspension travel and an extra 1.9” of ground clearance. It also provides a manual clutch for a more exciting experience, but there’s an electric start (with kickstarter back up) to get the fun started quickly.
2016 Kawasaki KLX110 http://www.Totalmotorcycle.com Key Features
The biggest challenge in enjoying the KLX110 or KLX110L’s amazing off-road capabilities is figuring out who’s going to ride it first – because its compact dimensions, simple-to-use features, and choice of 2 models were designed for a wide range of beginning riders aged 13 and up.
The KLX®110 motorcycle is a versatile off-road bike with a low seat height, long travel suspension and an automatic clutch for a fun, confidence inspiring ride.
•112cc air-cooled, four-stroke engine provides smooth power and rock solid reliability
•Four-speed transmission with automatic clutch for stall-free shifting
•26.8-inch seat height
•Sporty styling featuring lime green bodywork for race-inspired good looks
2016 Kawasaki KLX110 - http://www.Totalmotorcycle.com USA Specifications/Technical Details
US MSRP Price: $2299 USD
Canada MSRP Price: $2649 CDN
Power
Engine
4-stroke, 1-cylinder, SOHC, Air-cooled
Displacement
112cc
Bore x Stroke
53.0 x 50.6mm
Compression ratio
9.5:1
Fuel System
Keihin PB18
Ignition
DC-CDI
Transmission
4-speed
Final Drive
Chain
Performance
Front Suspension / Wheel Travel
30mm hydraulic telescopic fork / 4.3 in
Rear Suspension / Wheel Travel
Swingarm w/single hydraulic shock / 4.3 in
Front Tire Size
2.50x14
Rear Tire Size
3.00x12
Front Brakes
Mechanical Drum
Rear Brakes
Mechanical Drum
Details
Frame Type
Backbone frame, high-tensile steel
Rake/Trail
24.8° / 2.0 in
Overall Length
61.4 in
Overall Width
25.6 in
Overall Height
37.6 in
Ground Clearance
8.5 in
Seat Height
26.8 in
Curb Weight
167.5 lb**
Fuel Capacity
1.0 gal
Wheelbase
42.3 in
Color Choices
Lime Green
Warranty
6 Months
Kawasaki Protection Plus™ (optional)
12, 24, or 36 months
