Hello Forum,
This is my first post so I don't know if I am doing
this right.
I have today just purchased my XJ650RJ Seca '82.
The starter button does not turn over the engine,
but to appy 12 volt directly to starter, it spins the
engine ok. I suspect a simple solution.
Jim
XJ650RJ Seca '82
SJ750RJ Seca '82
Mena, AR, USA
New 650 owner
New 650 owner
"If it is to be, it is up to me"
will not crank with button
Check that the safty on off switch is on the on position. Also this system has a solenoid simular to the ford automobiles had in yrs past. Check that the connections are clean and tight. I owned an XJ650 maxim yrs. ago, it was one of the best bikes that I ever owned. Hope this helps you find the problem.
- Wizzard
- Legendary 1000
Congratulations and welcome to the forums Jim .
Regards, Wizzard
Regards, Wizzard
hey!
hey i have the same bike!
check it out in the yamaha pics!
ehh can we see yours?
couldnt it be the sidestand switch or something?
anyway welcome!!
also theres a cj only website @ www.xjowners.com
anyway welcome!!
jean b.
jawa350 w/sidecar
suzuki rv90
yamaha xj650 seca
jawa350 w/sidecar
suzuki rv90
yamaha xj650 seca
Thanks
Thanks for the warm welcome and for
your advice.
The red/w wire to the starter solenoid
is not hot with the ignition switch on.
I am chasing continuity using the
diagram on the XJCD.
Will post pics as soon as I learn how.
Jim
your advice.
Jim
