Tachometer on CB550SC Not Working gerpena
gerpena
#1 Unread post by gerpena »
I replaced my key ignition switch with an aftermarket one, and though
the bike now starts fine, now the tachometer does not work.
Also, the front panel lighting is different-- for instance my nuetral
light turns on if i try to start the bike in gear but it wont stay lit
if i shift the bike to neutral. This did not happen before.
The overdrive light used to come on when i ran the bike in 6th, but it
doesnt anymore.
The speedometer is working fine however.
Advice? Suggestions?
#2 Unread post by dr_bar »
How about going to a bike wrecker and see if you can get an OEM part...
gerpena
#3 Unread post by gerpena »
dr_bar wrote:How about going to a bike wrecker and see if you can get an OEM part...
would have done so happily, but i was unable to find one. why should it matter anyway, i thought the ignition system was merely a switch? thats all i changed....
Gilfy650a
Location: Northern Kentucky, "Like the rest of KY only better"
#4 Unread post by Gilfy650a »
Did you reattach everything behind the gauge cluster, it could be that you didnt tighten everything up correctly?
Currently Bikeless
SUPER AWESOME VILLAINS FOREVER!!
Its settled Suzuki SV650 as next bike. :D
nitrus
Re: Tachometer on CB550SC Not Working gerpena
#5 Unread post by nitrus »
gerpena wrote:I replaced my key ignition switch with an aftermarket one
Get a service manual, check the wires that you may have unplugged.
a neutral light is usually part of the starting circuit. Does the bike start
with the bike in gear and not in neutral?.
