I replaced my key ignition switch with an aftermarket one, and though
the bike now starts fine, now the tachometer does not work.
Also, the front panel lighting is different-- for instance my nuetral
light turns on if i try to start the bike in gear but it wont stay lit
if i shift the bike to neutral. This did not happen before.
The overdrive light used to come on when i ran the bike in 6th, but it
doesnt anymore.
The speedometer is working fine however.
Advice? Suggestions?
Tachometer on CB550SC Not Working gerpena
Re: Tachometer on CB550SC Not Working gerpena
gerpena wrote:I replaced my key ignition switch with an aftermarket one
Get a service manual, check the wires that you may have unplugged.
a neutral light is usually part of the starting circuit. Does the bike start
with the bike in gear and not in neutral?.
