Pilot Air Jets and Main Air Jets
mrhoades
#1 Unread post by mrhoades »
I am looking for somebody that sells Pilot Air Jets and Main Air jets for a 1980 Yamaha 650 Maxim I have torn apart the carbs completey (see idles rough post). In the process, all jets were so junked up (rust, sludge) that I am having to drill out what is left of the jets (brass breaks no matter what I try and penetrating oil is not helping). I can find the main and the pilot jets all day long, just no the air jets.
TechTMW
#2 Unread post by TechTMW »
You need new carbs. The air jets MAY be available from the carb manufacturer, but if you've been using a drill in there, you will need new ones.
Check ebay, junkyards, etc. If the next set of carbs is gunked up, be patient, buy a carb dip or get them professionally dipped. There are plenty of chemicals out there that will clean a carb without resorting to using a drill. Compressed air works wonders for blowing grime out as well.
mydlyfkryzis
Years Riding: 42
#3 Unread post by mydlyfkryzis »
Not sure for your model, but I bought a rebuild kit for my CB360, it came with new jets. The kit was around $24. E-Bay usually has scads of them...
Richard - Fully Dressed
Naked 1976 Honda CB360T
