What type of lubrication system
tewillia
#1 Unread post by tewillia »
Does a 2000 Yamaha R1 have a wet sump or a dry sump lubrication system?
niterider
#2 Unread post by niterider »
The only bike that I believe with a dry pan is the Harley and even than I am not really sure of that. I know it has an oil tank.
1993 750 Vulcan
one seater
ear shave, pod filters
rear turn signal relocation
lowered rear 2" soft tail
horn relocation
#3 Unread post by BuzZz »
Wet-sump systems have no oil tank, as was mentioned. Harley's twins are the only modern bikes that spring to mind with this set-up. The R-1, and every other sportbike i can think of, use a wet-sump engine. If you add oil to the engine cases, it's probably a wet-sump. If you add oil to a separate tank, remotely mounted elsewhere on the bike, it's a dry-sump.
ZooTech
Years Riding: 18
#4 Unread post by ZooTech »
And what about the Buells with the oil-filled swingarms? :laughing:
mydlyfkryzis
Years Riding: 42
#5 Unread post by mydlyfkryzis »
ZooTech wrote:And what about the Buells with the oil-filled swingarms? :laughing:
Dry Sump
Sump is bottom of engine. If the oil is not in the bottom of the engine, it is a dry sump.
Richard - Fully Dressed
Naked 1976 Honda CB360T
ZooTech
Years Riding: 18
#6 Unread post by ZooTech »
Dry Sump
I know, I was just picking on BuzZz's statement.
#7 Unread post by BuzZz »
Buells ain't sportbikes, they're Hooligan bikes..... the best kind of bike. :mrgreen:
