What are the effects of bad vacuum
beerbaron
#1 Unread post by beerbaron »
I had diaphragm on my carbs that had some little bubles in it (not pearced). And I was wondering what would be the trouble if this diaphragm would not create the proper vacuum? It's an inline four.
BeerBaron
#2 Unread post by BuzZz »
No vacuum doesn't suck. :mrgreen:
#3 Unread post by BuzZz »
Except sometimes, when it does. Like when your carbs don't operate properly. And that is what happens when the diaphrams on the slides have holes in them.
Cockney Rebel
#4 Unread post by Cockney Rebel »
With no vacuum you would get no fuel to your carbs ,the vacuum opens the fuel tap
Old bikers never die they just ride off into the sunset.
#5 Unread post by BuzZz »
Cockney Rebel wrote:With no vacuum you would get no fuel to your carbs ,the vacuum opens the fuel tap
True, if it's the petcock diaphram with a hole in it. If it's the diaphram on the slide in the carb, then the slides don't see the correct vacuum signal and react accordingly.
Either way, a diaphram is a diaphram and should not have holes in the membrane...... :lol:
beerbaron
#6 Unread post by beerbaron »
Could this lead to a sudden loss of power at high RPM range (only in charge)?
BeerBaron
