Front Brake Question
MikeyDude
#1 Unread post by MikeyDude »
Well, we warmed up a little bit today and I pulled my Harley FXD out and gave it a good cleaning and waxing. As I was putting it away I noticed that the front brake has started moaning/squeeking (while braking). It's not your typical high pitched squeel, bit a medium pitched moan. It squeels moving forward as well as backward, but only while it's engaged.
As I was cleaning things I wiped down the front rotor with a damp cloth. I'm almost positive there was nothing on it except maybe some water. No wax at all... of this I am positive.
Is this anything to be concerned about? Did I screw something up by wiping the rotors down? Is there anything I can look for to see what potential issues might develop?
Thanks
~ It's not the quantity of miles -- It's the quality of the ride ~
storysunfolding
Years Riding: 22
#2 Unread post by storysunfolding »
Spray it down with brake cleaner just to be sure. You didn't mess up hte rotor by wiping it with a cloth. Curious though, when was the last time the brake fluid was changed?
My Blog
Grasp life by the handlebars
MikeyDude
#3 Unread post by MikeyDude »
I'm not sure when it was changed, I got it used. It just had it's 5000 Mile service tho.
ZooTech
Years Riding: 18
#4 Unread post by ZooTech »
It should be changed every two years. I use Valvoline synthetic. As for the noise, you may just want to ride it again to see if it persists.
