Wont go off idle
bobdog
Wont go off idle
#1 Unread post by bobdog »
Ive got a 98 750 nighthawk that will idle fine sounds good as soon as I give it any trottle it dies no sputter or anything just stops.Any leads would be great. Im normaly not bad at this but Im alittle lost. Help please .thanks Bobdog
skoebl
#2 Unread post by skoebl »
Carb cleaning maybe? :?
I dunno...sounds like something carb related at least
(sorry for the lack of any real answer...but at least it's a start...maybe...lol)
SV650 K6 <---Suuper Awsome bike
[quote="V4underme"]
If I didn't feel like a monkey &*$%ing a football when I sat on a sporty, I'd probably own one.[/quote]
bobdog
Thanks
#3 Unread post by bobdog »
I took off the tank and put my air to the fuel line. Then opened each drain on the carbs one at a time and bingo it runs great. Im not sure what was clogged but it came out.Thanks for the reply. I was surprised at how nice of a bike this 750 is . It goes good handles ok . I m used to my 800lb valkyrie.
old-n-slow
Re: Thanks
#4 Unread post by old-n-slow »
bobdog wrote:I took off the tank and put my air to the fuel line. Then opened each drain on the carbs one at a time and bingo it runs great. Im not sure what was clogged but it came out.Thanks for the reply. I was surprised at how nice of a bike this 750 is . It goes good handles ok . I m used to my 800lb valkyrie.
Sounds like you might have had water in the carbs. You might want to drain the tank as your reserve could be of no value to you (It might be water). Tanks can get condensation in them if the bike sits. Depends on humidity and temperature. Worth a look anyway. :?
GarryS ---- "We learn from experience that men never learn anything from experience."
bobdog
#5 Unread post by bobdog »
Thats a good Idiea all do that. Thanks Bob
