Wont go off idle
Wont go off idle
Ive got a 98 750 nighthawk that will idle fine sounds good as soon as I give it any trottle it dies no sputter or anything just stops.Any leads would be great. Im normaly not bad at this but Im alittle lost. Help please .thanks Bobdog
- skoebl
- Legendary 300
Carb cleaning maybe?
I dunno...sounds like something carb related at least
(sorry for the lack of any real answer...but at least it's a start...maybe...lol)
SV650 K6 <---Suuper Awsome bike
[quote="V4underme"]
If I didn't feel like a monkey &*$%ing a football when I sat on a sporty, I'd probably own one.[/quote]
[quote="V4underme"]
Thanks
I took off the tank and put my air to the fuel line. Then opened each drain on the carbs one at a time and bingo it runs great. Im not sure what was clogged but it came out.Thanks for the reply. I was surprised at how nice of a bike this 750 is . It goes good handles ok . I m used to my 800lb valkyrie.
- old-n-slow
- Legendary 300
Re: Thanks
Sounds like you might have had water in the carbs. You might want to drain the tank as your reserve could be of no value to you (It might be water). Tanks can get condensation in them if the bike sits. Depends on humidity and temperature. Worth a look anyway.bobdog wrote:I took off the tank and put my air to the fuel line. Then opened each drain on the carbs one at a time and bingo it runs great. Im not sure what was clogged but it came out.Thanks for the reply. I was surprised at how nice of a bike this 750 is . It goes good handles ok . I m used to my 800lb valkyrie.
GarryS ---- "We learn from experience that men never learn anything from experience."
