Repairing a small crack in the fairing
Marley
#1 Unread post by Marley »
My bike has a small crack in the fairing around the right blinker. It is maybe an inch long on the outside.
There is also a plastic casing that surrounds the blinker on the inside part of the fairing that is cracked. These cracks are connected.
What can I use to seal these cracks up? Any ideas?
Thanks
storysunfolding
Years Riding: 22
#2 Unread post by storysunfolding »
I would either glue or weld the plastic back together, then use bondo to fill the crack and repaint the area.
My Blog
Grasp life by the handlebars
ZooTech
Years Riding: 18
#3 Unread post by ZooTech »
Five minute epoxy and a steady hand. Be sure to drill a hole through the plastic at the end of the crack to prevent it from spreading.
