1995 Yamaha V-Max Dyno Pulls with Nitrous
fyi
#1 Unread post by fyi »
Well, we ran the machine on the chassis dyno on Monday and the results were interesting.. The bike is stone-stock and has 35,000 miles on the clock and it pulled 115 RWHP/79 RWTQ naturally aspirated- the best average of 3 pulls.
After we changed the sparkplugs and switched the engine oil to 15w/40synthetic Redline oil, it picked up to 118 RWHP/81 RWTQ naturally aspirated- the best average of 3 pulls.
We turned the choke on slightly to richen it up for the next run and fogged the airbox with nitrous at the air-intake snorkels and it pulled 140 RWHP/91 RWTQ!
It *loved* it!!! :shock:
Now I just need to configure some kind of system I can adapt n20 to this bike and I'll post pictures/dyno charts when I can for those interested... :)
-john
Heimdall Einherjar
#2 Unread post by Heimdall Einherjar »
Nice, but I was under the impression the V-Max did 145 hp stock...
DivideOverflow
#3 Unread post by DivideOverflow »
145 at the crank. Manufacturers never give the power to the wheels (as is measured from a dyno).
2008 BMW K1200S
2003 Z1000 - For Sale
2004 Hyosung GV250 - sold
fyi
#4 Unread post by fyi »
Correct. :scooter:
I've experimented around a bit more with the dry-shot of n20 on this thing and have been able to richen-it up pretty easily using the choke circuit of the carbs. I've machined a detent stop for the choke lever so that when I want n20 use, all I have to do is reach down and flip the choke lever down until it stops at the detent position I pre-selected, for the correct amount of enrichment. It only takes a *very* small amount of choke to richen the AFR a *bunch* and so far, it's been quite effective/repeatable...
Once I get this thing completely sorted out and can obtain repeatable results pull after pull, I'll post what i know and how it works. :)
-john
