Jetting a 2001 Honda Shadow Spirit 750
CORSCO
#11 Unread post by CORSCO »
Here are the settings I use:
Needles on groove #3 from the top.
Install the new slide spring, to slow that boy down (if epuipped)
Without baffles....main jet...102 in the front and 104 in the rear
With baffles...main jet...100 in the front and 102 in the rear
Mixture screw 3 turns out
Good Luck. If these are the same settings you have, it must be something you did, sorry. Unless there are some mountains in New York that I am not aware of :wink:
Edywazoo
#12 Unread post by Edywazoo »
Tried both vet options, and turned mixture screw out the 3 times. The problem w/tuning the mixture screw w/the airbox totally on is that now I cant get to one of the carbs mixture screw. So how would I adjust it?
I guess I'm gonna have to settle w/the fact that the carb is out of sync.
only thing left i guess
Edywazoo
#13 Unread post by Edywazoo »
Call me stupid..............................Someone suggested to put the air box on.............................I did. But it was out of frustration!!!! I threw my hands up and said "enough of the crap". I'm putting it all together and taking it to the dealer in the morning. One more go w/it down the highway and Holy "poo poo"! Its working?
You guessed it.................the istallation of the stock air box was the issue after all. I wish I would have kn own this 3 weeks ago. But I guess I should have............................didnt think it could be soemthing so obvious.
thanx for all your help people. Greatly appreciated.
CORSCO
#14 Unread post by CORSCO »
CORSCO wrote:You WILL NOT get the stumble out of it while running it WITHOUT the air box. Please put the air cleaner assy. back on before you try and tweak it's running problem. When doing services on these bikes at the shop and synchronizing the carbs with the air filter cover off, the bike stumbles off idle.
Usually after the mixture screw is turned out past three turns, it's adjustment is done. Maybe go bigger on the idle jet.
I don't see why you would need to do being in New York.
I have done many of these and have never had a problem using the recommended settings.
How are the diaphrams, are they pinched?
Have you had the carbs synch'd? Taking them out as many times as you say you have can easily and probably have changed the setting.
Do not modify your airbox to try to get it to work. There is no need for that. The jet kit you have does not require any mods.
I will look tomorrow when I get to work and look through my notes on jetting for this model. I use Dyno-Jet which I think should be the same.
I hope my memory holds up, if it does, I will post with my settings.
That would have been me! Try reading these things once in awhile. :wink:
bok
#15 Unread post by bok »
gee Corsco, you sound like you might fix bikes for a living or something ;)
CORSCO
#16 Unread post by CORSCO »
bok wrote:gee Corsco, you sound like you might fix bikes for a living or something ;)
no...but I did spend a night at MotoF150 house.
#17 Unread post by BuzZz »
CORSCO wrote: no...but I did spend a night at MotoF150 house.
:laughing:
But did it cost you less than a Holiday Inn would have??? :mrgreen:
:twisted: what is your immortal soul worth? :lol:
CORSCO
#18 Unread post by CORSCO »
:laughing:
I did get a $5 meal and a free tank of gas out of it! Plus all the wisdom my puny little brain could handle. NO MORE OIL CHANGES FOR ME!!!
