750 honda no spark
750 honda no spark
I have a 1974 honda 750 with no spark. Any ideas where to start. The motor spins but no spark , tried other plugs,thanks
There should be a condenser (also called a capacitor) in the circuit. Check that. If your local shop doesn't have the equipment to do so you may have to just buy a new one and install it. Check wiring to the coil, and from the coil to the spark plug. If all wires are okay, check the coil primary and secondary windings. Most manuals will give impedence for both.
no spark
i ahve a 1981 750 and i wasnt getting spark until i tapped the coil with a small box wrench.
Rehab message board
Rehab message board
