2006 Honda VTR 250
2006 Honda VTR 250
Now if they can only bring out a 800cc version of it for North America.
ooo, and it's available in Yellow too. :D
From Honda Japan:
It probably will have the footwork whose feeling is better to everyday life. The modern design which is refined. Feeling the beat of V-Twin which bears the running which is good. Furthermore light conduct power is boosted, the tachometer of the seat high new equipment where the foot arriving is good. The steering wheel is grasped. And it starts running. It can encounter the scenery which is full in the shining where when the origin is different with just that.
Sorry only available in Japan right now... :(
Specs:
Type BA-MC33
Total length (m) 2.035
Full-width (m) 0.725
Total height (m) 1.055
Wheel base (m) 1.405
Roadspace (m) 0.155
Seat high (m) 0.760
Vehicle weight (kg) 155
Dry weight (kg) 141
Riding in a car fixed capacity (person) 2
Fuel consumption rate (km/L) 40.0
(60km/h fixed area travelling test value)
Minimum turning radius (m) 2.7
Engine type MC15E
Engine type Water cooling 4 stroke DOHC4 valve V type 2 cylinder
Total cubic displacement (cm3) 249
Inside diameter × distance (mm) 60.0×44.1
Compression ratio 11.0
The highest output
(KW [ PS ]/rpm) 24 [ 32 ] /10,500
Largest torque
(N m [ kg m ]/rpm) 24 [ 2.4 ] /8,500
Carburetor type VD10
Starting system Self system
Ignition device type Full transistor type battery ignition
Lubricating system Force splash combined use system
Fuel tank capacity (L) 13
Clutch type Wet multiple plate coil springs
Transmission type Regular gearing type 5 step return
Change gear ratio 1st gear 2.733
Change gear ratio 2nd gear 1.800
Change gear ratio 3rd gear 1.375
Change gear ratio 4th gear 1.111
Change gear ratio 5 speed 0.965
Reduction gear ratio (primary/second) 2.821/2.928
Caster angle (degree) 25 degree 30 minute
Trail quantity (mm) 96
Tire (before) 110/70-17 54H
110/70-17M/C 54H
Tire (after) 140/70-17 66H
140/70-17M/C 66H
Before the brake type Hydraulic type disk
After the brake type Hydraulic type disk
Before the suspension system Telescopic system
After the suspension system Swing arm system
Frame type Diamond
MASHBY
Years Riding: 20
#2 Unread post by MASHBY »
Great looking Bike even for a 250
Id choose this color scheme though.
#3 Unread post by High_Side »
Same old engine as our old '90 VTR250.....nuthin' wrong with that! They have made this Monster clone for the domestic market for quite a while. I think if we haven't seen it here yet, we are not about to......
#4 Unread post by Sev »
Looks like a slightly smaller version of the Honda Hawk.
jmillheiser
Legendary 2500
Legendary 2500
#5 Unread post by jmillheiser »
hmm, maybe make a 800ish cc version and bring it over here as competition to the monster and SV650
DivideOverflow
#6 Unread post by DivideOverflow »
I say replace the nighthawk 250 with that thing. We need more 250 choices in the states...
2008 BMW K1200S
2003 Z1000 - For Sale
2004 Hyosung GV250 - sold
< I Fly >
#7 Unread post by < I Fly > »
We definitely need that stateside.
Honda's 250 class bikes available suck!
"This member has been banned from the community due to showing a complete lack of basic respect for fellow community members." - Admin
jmillheiser
Legendary 2500
Legendary 2500
#8 Unread post by jmillheiser »
that would be a perfect replacement for the nighthawk 250.
