Oil?
Oil?
Ok, noob question deluxe here. Can I add more oil without necessarilly changing the oil outright? Despite that I just had it changed recently, my buddy told me today I needed some more. Can I mix motorcycle oils without any issues?
Current: 2008 Vulcan 900 custom
Previous: 1999 V-star 650 custom
sight glass for accuracy
I'm not sure about the 1999 V-Star's but the 06-07's have a sight glass. It's hard as heck to find if you don't know it's there, but left side, near your shifter is a small glass peep hole that has scribe marks for high / low to view the oil level. Make sure the bike is perfectly upright center when you check it (and I'd have a friend help unless you have a long handled mirror (my method) to view it while siting on the bike!
- Lion_Lady
- Legendary 1500
- Real Name: Pam
- Years Riding: 24
Keep in mind that oil will take a while to run down to the sight glass (don't pour and watch for the level to rise in the glass). It is better to add some, then run the engine then check and add again if needed. Run. Repeat.ZooTech wrote:As long as you have the necessary motor skills and dexterity to tip a quart bottle of oil, yes.buddhacide wrote:Is it possible to put too much in?![]()
Seriously, though, you absolutely can add too much oil and it is a very bad thing. Check your sight glass when filling.
Hopefully your manual tells how long you should wait after turning off the engine for the oil to settle where its supposed to.
Had a friend add almost 2 QUARTS too much oil to his BMW. Blew out gaskets and filled the air box with oil. That was an expensive fix as the bike needed to be towed to the dealer because it would NOT run.
P
- ZooTech
- Years Riding: 18
Totally unnecessary after the first run-and-check. Once the oil filter is full you can just add and watch the sight glass.Lion_Lady wrote:Keep in mind that oil will take a while to run down to the sight glass (don't pour and watch for the level to rise in the glass). It is better to add some, then run the engine then check and add again if needed. Run. Repeat.
Lion_Lady wrote:Had a friend add almost 2 QUARTS too much oil to his BMW. Blew out gaskets and filled the air box with oil.
Well that theory's out the window...Lion_Lady wrote:BMWs are generally WELL taken of by their owners.
- storysunfolding
- Years Riding: 22
Zoo should be limited to three smileysZooTech wrote:Totally unnecessary after the first run-and-check. Once the oil filter is full you can just add and watch the sight glass.Lion_Lady wrote:Keep in mind that oil will take a while to run down to the sight glass (don't pour and watch for the level to rise in the glass). It is better to add some, then run the engine then check and add again if needed. Run. Repeat.
Lion_Lady wrote:Had a friend add almost 2 QUARTS too much oil to his BMW. Blew out gaskets and filled the air box with oil.Well that theory's out the window...Lion_Lady wrote:BMWs are generally WELL taken of by their owners.
