R-Max USA by Roadmax Transmissions Shifts Into High Gear at PRO-ONE
October 31, 2006 - PRO-ONE Motorcycle Press Release
PRO-ONE Motorcycles Run R-MAX on Entire Line of Custom Bikes
October 31, 2006 ? Ontario, CA - R-Max USA by Roadmax Transmissions
supplies transmissions on all of the new 2006 PRO-ONE motorcycles.
R-max transmissions are standard equipment on the ROGUE (Softail Style
Pro-Street), DOMINATOR ( Pro-Street Quad Pro-Quad), VAPOR (Softail
Style Chopper) and HYPER-4 (Chopper Pro-Quad) and offer consumers a
selection of unique custom options found no where else.
What makes PRO-ONE Motorcycles unique are all of the custom features
that are built in-house by PRO-ONE including frames, forks, custom
bars and rugged steel tanks and fenders.
Additional standard equipment includes R-Max USA by Roadmax 6-speed
right side drive, 3? belt drive, Dakota Digital gauges, and TP 121 or
124 CI power plants.
?The technology we use in the transmission including our proprietary
shift drum allows the PRO-ONE Motorcycles to shift consistently,
smoothly and effortlessly,? said Jaz Zbiegien, Sales and Marketing
Manager, R-Max USA by Roadmax. ?We are excited about PRO-ONE?s
decision to partner with us and we look forward to working with them.?
The R-Max right side drive six speed transmission utilizes a 2.94:1
1st gear ratio, 2.21:1 2nd gear, 1.60:1 3rd gear, 1.23:1 4th gear,
1.00:1 5th gear, and .86:1 overdrive gear ratio for 6th gear.
Internals consist of SAE8620H precision cut full width gears with
increased dog area. They are back cut and diamond media blasted for a
very smooth and quiet operation.
The shift forks are made from heat treated ALBC3 alloy, which gives
the forks superior strength. Used in combination with the R-Max USA by
Roadmax proprietary shift drum it offers enthusiasts smooth positive
shifting and longer reliability.
?The R-Max USA transmissions are dependable, the fit and finish is
superb and they come with a good warranty,? said Josh Siedner,
Operations Manager, PRO-ONE. ?Not only do they look good, the shifting
is smooth and the performance is outstanding.?
About R-Max USA by Roadmax
At R-Max USA, high-quality products are made for Harley-Davidson
styled motorcycles that not only look good, but increase the
performance of your motorcycle. Dealers, custom bike fabricators,
bike builders and OEM manufacturers utilize our transmissions,
Springer front ends, starters and open primary. R-Max USA is located
at 1455 South Campus Ave. Unit E, Ontario, CA 91761. For more details,
call 1-866-R-MAXUSA.
