94 XV 535
94 XV 535
#1 Unread post by Johnj »
My brother-in law just picked up a 535 Virago. How the heck do you check the oil on this thing? There is an inspection cover on the left side, but I don't see any oil when I look in there. Help.
#2 Unread post by Sev »
Stupid question: are you sure there's oil in it?
#3 Unread post by Johnj »
There's oil seeping out the right side engine cover so I know there's some oil inside. I don't see a sight glass or anyplace you can see the level of oil. I just don't believe that we need to fill the left engine dase with a couple quarts of oil.
Ninja Geoff
Real Name: Geoff
#4 Unread post by Ninja Geoff »
Johnj wrote:There's oil seeping out the right side engine cover so I know there's some oil inside. I don't see a sight glass or anyplace you can see the level of oil. I just don't believe that we need to fill the left engine dase with a couple quarts of oil.
Is there a dipstick attached to the filler cap? And if there isnt, WAS there one that just broke off?
#5 Unread post by Johnj »
Ahhh... I found a pdf owners manual online. There is a sight glass on the left side, low on the engine. I don't know how we missed it.
http://www.artsturm.ee/virago_535/Virag ... 28_129.pdf
dablade
Real Name: Perry Crowell
My Motorcycle: 2005 Yamaha FJR 1300, 2004 GL1800 ABS
#6 Unread post by dablade »
I feel your pain. I bought a 89 Yamaha 250 with an oil leak, and had the sight glass, but I couldn't discern the oil level. So I fixed the oil leak, and changed the oil. And I still cannot tell what level the oil is at. But I rest assured that the right amount is in there now. This bike is an occasional rider, so the oil changes will just have to be more frequent. :? Good luck with the 535.
