Sticking Throttle Problem
floatsmyboat
#1 Unread post by floatsmyboat »
I recently purchased a 1979 Suzuki GS 750 L that looks like new, but I am having problems with the throttle sticking. If I give the throttle a quick snap, it idles down. I have checked, and the throttle cable pully is always tight againts the idle stop. I took the tops off the carbs, and everything looks tight. Anyone have an idea what may be causing this problem?
Thanks,
Greg
Gadjet
Real Name: Owen Clark
Years Riding: 19
#2 Unread post by Gadjet »
you might just need to give the cable a shot of lubrication
1983 Suzuki GS650GL (sold)
2005 Kawasaki KLR 650 (sold)
2020 KTM 200 Duke
IBA#20953
IG: @greenmanwc
floatsmyboat
#3 Unread post by floatsmyboat »
It isn't the cable, because the pully is always tight against the idle adjustment screw, yet the engine races till I snap the throttle.
Greg
#4 Unread post by BuzZz »
Just to make sure, check that you have a small amount of freeplay in the throttle cable. The choke might be sticking a bit as well. and while your checking stuff, you can try adjusting the idle mixture screws. Just make small adjustments and test the return to idle before making another adjustment.
And it NEVER hurts to lube your cables. Silky smooth action is always welcome in the controls. :wink:
