Well, I finally got a new battery for my 92 Katana.. but she still won't turnover! I'm desperate for ideas on what I can do.. I'm wondering if maybe the idle is too high or possibly too low.. or something else? Ahhhh, I haven't ridden my baby in over a month and I'm going crazy trying to get it to start!
idle speed is only an issue when she will turn over. Check your fuses, and go over all your connections. Make sure the starter solenoid and starter switch is working
Do your lights work? headlight, tail light, turn signals, break light, guages, neutral indicator, that kind of thing? Did you charge the battery out of the box?
mydlyfkryzis wrote:Mine will start with the throttle pretty far open.....
Are you sure the "idle was high". The choke sets the idle high by design...
Just seems odd..
The choke actually either enriches the fuel or restricts air. Turning the idle up opens the throttle a bit and allows more air into the system. I can see this happening but it would definitely have to be open a bit more than you'd expect it to ever get to naturally
