How to purchase a good quality chaps?
Publish Date : 3/16/2005 5:32:00 AM Source : Health Section epressNewsline.com
Before buying chaps, you need to take care of some points in mind. Chaps are expensive and can range in price for $90 to $500. You need the trick before purchasing quality chaps without spending too much money. This can be quite tricky, because of the different qualities of leather. Some branded chaps are very expensive, and even this becomes troublesome as in some cases you pay for the name on the chaps and not the quality. If you follow some of the ideas below, you can be reassured that you have not over paid for your chaps.
The grade of the leather is the biggest factor in determining the quality of chaps. Soft to the touch leather, rough, rigid leather, or grainy leather are all different grades. Generally, name brand chaps are outrageously more expensive than a "generic" name. If you are willing to pay to have your chaps say the reputable name, then be prepared to deal with a less quality.
Another factor is the accessories that you look for in your chaps. If you are buying very detailed chaps, they will be more expensive. Chaps with frays down the leg will be at a higher price. If they have frays around the waist or on the back, they will be higher priced. Plain chaps that come standard and are a standard, ordinary size are generally the least expensive. Chaps should be purchase in a style that will not go out. Chaps will last an eternity and if you buy them in a style that is odd or may turn into a fad, this can be costly. They best way to purchase chaps is to buy plain and add on as needed with accessories that are removable. This will ensure that they will not go out of style.
Where to purchase from: Chaps can be purchased from a motorcycle store, a western company, or directly from a leather shop. Generally the most over priced are- the motorcycle stores and western shops. When purchasing from a leather shop, you can hunt around for sales and clearance items. It is hard to find discounted chaps at motorcycle and western shops because chaps sell and there is no need to discount the items.
Finding a pair of chaps that fits you well can also be a task. Chaps are heavy, constricting outerwear that must be tight fitting. They are worn over jeans or pants; therefore, the jeans need to be very tight fitting. When trying on chaps, you should have a pair of tight fitting jeans on to measure the chaps and the way they fit. Chaps should be somewhat tight, but comfortable. They should feel like they are protecting your leg. Generally chaps are sold in sizes like: S, M, L, and XL. There are more sizes, but they are not sold in sizes like jeans. This is because chaps are somewhat adjustable. They secure on the sides with zippers or buttons. The top is a belt, with a drawstring in the back for adjusting waist length. The pants legs can simply be cut to the appropriate length.
So, the purchase of chaps should be taken seriously. You should look at all the options that you have and compare prices, styles, and qualities. With the proper use and care, chaps should withstand a lifetime of wear and tear. Chaps are an investment and should be taken seriously. They are a great way to protect yourself and feel secure while wearing them.
ronboskz650sr
#2 Unread post by ronboskz650sr »
Great advice, mike! I just wanted to share a technique . When I cut my chaps to length...years of cycling made a large thigh necessary...I sealed the cut thread with clear two part epoxy, instead of taking them to a shop and having them sewn. It allowed me to do the fitting myself at home and start wearing them in a couple of hours, instead of days.
Ride safe...God bless!
-Ron
A lot of riders really enjoy using chaps for cold days as the wind doesn't cut through them like jeans do.
Mike.
oldnslo
Real Name: Lamont Cranston
Years Riding: 20
#4 Unread post by oldnslo »
I guess I've never seen much value in chaps. If you crash, your most sensitive parts are exposed to be uprooted and cast aside, and if you land on your backside, you are only wearing denim. Armored fabric ventilated pants make more sense to me , and cost far less.
But, that's just an opinion.
John
"83 XJ900RK
