Helmets
Helmets
I'm in the process of deciding what kind of helmet to purchase. I have pretty much decided on a full face but was wondering if there were any thoughts about brand and fibreglass vs poly carbonate. Welcome your thoughts.
- ILOVECRUISER
- Nibblet99
It was my understanding (read: deep, dark, distant memory) the fibre ones have a longer shelf life, and aren't susceptable to problems cause by solvents found in sticker glue.jonnythan wrote:The shell material really doesn't matter a bit.
(something like 4-5 years as opposed to a poly carbs 2-3 years - either way 1 impact voids the remainder of the lifespan on both though, which you should expect to happen)
I could however be very, very wrong, so please do some research rather than taking what I've written here as fact
- jonnythan
The shell material is not the limiting factor in shelf life - the EPS foam is.Nibblet99 wrote:It was my understanding (read: deep, dark, distant memory) the fibre ones have a longer shelf life, and aren't susceptable to problems cause by solvents found in sticker glue.jonnythan wrote:The shell material really doesn't matter a bit.
ABS and other plastics should not be damaged by sticker glue, either.
