1982 CM450A...horn works in low, but not high
dweiss
Real Name: Debra Weiss
Years Riding: 2
My Motorcycle: 2009 QLink LG250
#1 Unread post by dweiss »
So my bike is now 95% restored. I have one small glitch that even my Clymer book can't help me with.
While in gear, my horn will work in low. As soon as I click up to the high gear, the horn does not work.
Suggestions?
Debbie Weiss
www.superstitionranch.com
"I don't own my horses, they own me. It is a relationship that I have no plans of changing".
Proud owner of a 2009 QLink LG250
Past owner of a 1982 Honda CM450A
storysunfolding
Years Riding: 22
#2 Unread post by storysunfolding »
that doesn't make sense to me at all. The gear shift is independent of the horn circuit. Is your charging system ok? It may be that in a higher gear you're staying in lower rpms and the battery is getting drained... only thing I can think of... maybe a bad horn?
My Blog
Grasp life by the handlebars
fireguzzi
Real Name: Trevor
#3 Unread post by fireguzzi »
Maybe just a bad connection? The higher speeds maybe shakin something loose.
dweiss
Years Riding: 2
#4 Unread post by dweiss »
I know that the horn is good, I did the Clymer test that has you disconnect the horn wires and attach them to a 12V battery. The horn sounds good and strong.
I do have a feeling that it has to do with RPM's...but I have no clue how to address that. My carbs are balanced, and the bike runs VERY smooth, so I don't want to alter RPM's just to make the horn work in high (above 45mph).
I haven't detected any other electrical issues, so I don't think it is a charging issue...but, I am a newbie.
Any other thoughts? My mechanic, who is a Honda classic bike certified mechanic, jokingly says I have a ghost in my bike.
Thanks for all the responses so far...
Debbie Weiss
dweiss
Years Riding: 2
#5 Unread post by dweiss »
Well shoot, it can't be due to RPM's. According to my Clymer book:
"The alternator generates an alternating current (AC) which the rectifier converts to direct current (DC). The regulator maintains the voltage to the battery and load (lights, ignition, etc.) at a constant voltage regardless of variations in engine speed and load."
Okay, since low RPM will not affect electrical at this point...I'm lost.
Suggestions?
~Debbie
Debbie Weiss
storysunfolding
Years Riding: 22
#6 Unread post by storysunfolding »
Debbie, that assumes the alternator and rectifier are working properly. I'd follow fireguzzi's suggestion first to see if it's a bad connection in the horn circuit then go through this diagnostic
http://www.electrosport.com/technical-r ... iagram.pdf
My Blog
dweiss
Years Riding: 2
#7 Unread post by dweiss »
Will do. Thanks! You guys are great!
Debbie Weiss
silverwinginit
1982 CM450A... horn works in low, but not high
#8 Unread post by silverwinginit »
Hello DW the tbl may be fixed already but I do see a few missing facts or at least good questions not addressed... for instance...why must your bike be in gear or even motor fired up?... will the horn work if you just turn on the key?.... will the horn work when you put it in neutral?..also is the wiring harness connected to the correct circuit? not reversed in any way? also when you go to a high gear do the lights dim as well indicating a problem with the voltage out put ..hard to check by yourself but maybe you can ride behind someone who can look at your headlights while you go thru the gears...just a few ideas. Hope you fix the problem I put together a 1952 "k" model Harley from 3 boxes of parts and that included the engine timeing gears and transmission which was in the same case in those older bikes and all I had was the HD service manual to guide me so I can sympathize with your situation. :frusty:
winginit
dweiss
Years Riding: 2
#9 Unread post by dweiss »
Update...the bike was in the shop this past week, and they found a connection or two in the harness that were a little corroded. After cleaning the connections, the horn worked; with key on, with bike turned over and in any gear, etc. Thank you to everyone who responded!
~Debbie
Debbie Weiss
