1986 suzuki calvalcade just clicks no start
roughmetal
#1 Unread post by roughmetal »
this bike sat a few years i got it started in about 10 min after i got to the fuel ports road it a few weeks started running better and better .then battery died again and again replaced rectafier and all better .Now when i try to start i hear a click but no start wait a min.and hear a different type of click and try again sometimes it will start others not any idea???? O-yea when it does decide to turn over it starts very strong like nothing was ever wrong thxs for any help in advance (roughmetal)
ride upstate new york
Ltdave
#2 Unread post by Ltdave »
make sure your starter button is clean and not all corroded or spider infested. it sounds like the contact is really hit or miss...
check the contacts on the starter solenoid and relay as well...
just a guess
1981 XJ550H
1982 XJ750RJ
1983 XJ900RK
A veteran is someone who at one point in his or her life wrote a check payable to The People of the United States of America for an amount of "up to and including my life".
#3 Unread post by Wrider »
I'm guessing first off that it's a weak battery. Test it when there's no load on it, you should get about 12 volts, and then again while cranking the bike over, it shouldn't go below 10 volts. If it does you need a new battery or a trickle charger to bring that one back to life.
If that's not it then I vote for a flat spot on the starter...
roughmetal
#4 Unread post by roughmetal »
flat spot in starter sounds about right do you know where i can find my starter prob. sounds like dumb question but if u have seen these bikes you will uderstand
#5 Unread post by Wrider »
Yeah I know what you mean, fully faired touring bikes are not easy to work on... I honestly don't know where the starter is on there. Chances are it's on top of the bottom engine case right behind the cylinders.
