Massachusetts inspection
vinniepenn
Real Name: Vincent Pennachio
My Motorcycle: 2001 Kawasaki Vulcan Nomad
#1 Unread post by vinniepenn »
While trying to get a sticker for my bike, i was informed i would fail because my auxillary lights do not turn off when i switch on my high beam head light. Considering most bikers would like as much light as possible to be seen as well as to see i thouht this was crazy, however after checking the rmv regs. this is correct. Stupid as it is it does say that in the motorcycle inspection rules. Has anyone else been burdened by this and if so how did you get around it.
Re: Massachusetts inspection
#2 Unread post by dr_bar »
Maybe put them on a seperate switch. Temporarily switch the source to a lead off of the low beam light.
erbgottie
Real Name: James
#3 Unread post by erbgottie »
Don't have that problem in NC or VA, maybe you should move down south..................or take dr_bar's advice which ever you prefer :)
2006 Suzuki SV650S
2003 Honda RC51
