2012 Bimota DB9 Brivido - Voted: Uncool
Your Coolness Factor of the 2012 Bimota DB9 Brivido is...
View results
More photos and information: http://www.totalmotorcycle.com/motorcyc ... rivido.htm
Burning and agile
A sport bike on the capacities, created for those who want an excellent way of any road.
And 'the roadster that comes from the DB8, which maintains the standards of excellence, although the triangle, seat-footrest-tank has been thoroughly reviewed to ensure a more comfortable ride in' urban use.
Also different engine than the DB8, this roadster is used a 'twin evolution of the "L" on a calibrated power more suited to the characteristics of the bike, brighter at low and mid-range where the torque delivery is prompt and linear.
2012 Bimota DB9 Brivido Model Highlights
It is a true roadster, the taut lines and the small fairing pronounced forward to give this bike look aggressive.
Colors in the traditional Bimota, where the white and red, to be in conflict with the carbon black which are widely used for the construction of superstructures.
A bike where elegance and determination go hand in hand, a look enhanced by the quality of finishes from solid plates Bimota which are left intentionally exposed.
2012 Bimota DB9 Brivido Features and Benefits
Technology
Thrill DB9 is powered by a twin engine "L" from 1198 cc, capable of delivering a power output of 162 hp at 9,500 rpm and maximum torque of 128 Nm at 8,000 rpm. An engine equipped with multi-plate clutch in oil bath, designed for road use more than one mounted on sister sports.
All 'front two forks are mounted upside-down 43 mm while the rear uses a monoshock. Both systems are adjustable for preload, rebound and compression.
The Brembo braking system consists of two 320 mm discs with radial calipers with 4 pads separated, and a 220 mm disc with twin-piston caliper. In the "S" version the front brake system is equipped with single-disc system, peripheral, developed by Bimota Experience Department of incredible effectiveness.
The wheels are forged aluminum, a material that helps keep the weight within the 177 Kg
2012 Bimota DB9 Brivido - International Specifications/Technical Details
MSRP Price: See your local Bimota dealer for pricing.
Model Bimota Motorcycles DB9 Brivido
Valves per cylinder
4
Engine
The 2-cylinder, 4 stroke
displacement
1198cc
Bore x stroke
106x67, 9 mm
Compression ratio
11,5:1
supply
electronic fuel injection
Start
electric
Power
162hp @ 9500rpm
max
13.1 kgm @ 8000 rpm
Transmission
chain
frame
NiCrMo4 steel with aluminum plates
front suspension
43mm upside down forks with adjustable preload DLC, compression and rebound
Rear suspension
monoshock adjustable for preload high and low speed 'extension and compression
front brake
2 320 mm discs, Brembo radial calipers with 4 pads separated
Rear brake
220mm disc, 2 piston Brembo caliper
Dry weight
177 kg.
Capacity tank
18 lt.
Speed max
260 km / h
front tire
120/70 ZR17
Rear tire
190/55 ZR17
Length
2040mm
width
830mm
height
1105mm
seat height
800mm
wheelbase
1435mm
jstark47
Re: This Week's Bike: 2012 Bimota DB9 Brivido - Vote & Discu
#2 Unread post by jstark47 »
That's just ugly. Blchh!! :disgust:
It might be a great bike, but.......... jeeze!! :puke:
#3 Unread post by dr_bar »
Just way too busy, not a clean looking bike at all...
Not cool...
HYPERR
#4 Unread post by HYPERR »
jstark47 wrote:That's just ugly. Blchh!! :disgust:
Has Bimota ever made a good looking bike? :boat:
Grey Thumper
Real Name: Dino
#5 Unread post by Grey Thumper »
It's just . . . unharmonious, isn't it?
Just one tiny example: why is the rear brake disk wavy, while the front disks are regular?
I voted: Uncool.
Based on the 2012 Bimota DB9 Brivido specifications alone it's pretty darn awesome, but it's looks are a fail. As mentioned above the 2012 Bimota DB9 Brivido is unharmonious in it's design and looks like Bimota just threw parts at it and see what stuck on the frame. In a strange way it's (sort of) like my old V-Strom, it looks good as a side profile but 3/4 profile it's not as flattering. I don't know what it up with the fairing design and the headlights nor the front and back disc designs or the lower cowling or the massive gas tank and tiny rear seat proportions.
Overall, it's a really quirky bike that would indeed generate quite a bit of interest at a bike night but perhaps not as many positive comments as the owner would like.
mogster
Real Name: MOG
#7 Unread post by mogster »
This bike looks like an ugly insect.
Uncool from me.
:party:
#8 Unread post by sunshine229 »
I voted Fail.
I'm all about the looks of a bike and this bike just doesn't do it for me whatsoever. I think it's cool that it is a 1200cc L twin that is light weight, but this kind of a bike is meant to be super hot and it just isn't that.
HYPERR
#9 Unread post by HYPERR »
It doesn't even look like a new bike, it looks kinda 1990-ish.... :?
What the hell, it's a hand made bike with a Duc motor, I voted cool. :ninja:
Not bad voting on this one, I knew it was going to be an interesting discussion/vote when I picked it. The reason I went with the 2012 Bimota DB9 Brivido was as I mentioned in my post it's a really awesome engine but the bike's looks really let it down and I didn't know if it would end up as awesome due to the engine or fail due to the looks of the bike... Seems it goes Uncool!
Awesome 0%
Cool 42%
Uncool 47%
Fail 11%
Great comments and thanks for voting on this one, the new Cool Wall bike is now up.
