1983 seca turbo starter
- Real Name: walt
- Years Riding: 20
- My Motorcycle: 1983 seca turbo xj650lk
starter does not engage when it does cranks two times and then just spins free help. purchase another used starter from ebay put it on does same thing.
- Johnj
- Real Name: Johnny Strabler
Re: 1983 seca turbo starter
Walt, the starter bendix or clutch needs attention.
- Real Name: walt
- Years Riding: 20
would it be hard to check the clutch i have used 2 starters and they are both doing the same thing. one more note clutch worked fine thur the gears. is in neutral when i try and start it. also my starter bendix does engade for 2 spins then starter just spins free.
- HYPERR
Sounds like the Starter clutch is bad...turbo wrote:would it be hard to check the clutch i have used 2 starters and they are both doing the same thing. one more note clutch worked fine thur the gears. is in neutral when i try and start it. also my starter bendix does engade for 2 spins then starter just spins free.
- Real Name: walt
- Years Riding: 20
is the Starter clutch hard to replace or fix what part would you order thanks.
- Johnj
I'd say medium hard to hard, I don't have one of those manuals
