Need help in Diagnostics Lights on 1965 M12 motor Cycle
Panther
Real Name: Brian Schweitzer
Years Riding: 15
My Motorcycle: M12 1965
#1 Unread post by Panther »
Please help point me in the right direction, My M12 Suzuki Motor cycle runs good , But all the lights stopped working I herd a pop like a fuse blowing, although there are no fuses on this bike, Is it the selenium rectifier that controls the power to the lights?
Re: Need help in Diagnostics Lights on 1965 M12 motor Cycle
#2 Unread post by Johnj »
Do you have a volt - ohm meter or DVM that you can read the voltage with?
Panther
Years Riding: 15
#3 Unread post by Panther »
Yes I have a Ohms/volt meter just not sure at what points I need to test, I believe the system is 6 Volt as that is what the bulds are rated for.
Brian
Panther
Years Riding: 15
#4 Unread post by Panther »
I have checked for continuity through the coil to the magneto pads to the attached wiring and I have continuity
#5 Unread post by Johnj »
OK set the meter for voltage and set the voltage above 12 volts. Now read how many volts you have across the headlight (while the bike is running).
Do you have a manual for the bike?
