For A LOT MORE photos and information click here: http://www.totalmotorcycle.com/motorcyc ... ero-SR.htm
2014 Zero SR on Totalmotorcycle.com
More power. Higher top speed. Greater acceleration..
The “R” configuration of the Zero S is designed for riders who simply want to go faster and accelerate harder. Aptly named on account of its performance and ability to dominate, the Zero SR features a larger 660 amp motor controller that provides 24% more power and 56% higher torque, delivering 106 ft-lbs. To accommodate the increased power, the Zero SR motor uses higher temperature magnets to ensure better performance during extended durations at higher speeds.
Capable of doing 0-60 mph in 3.3 seconds and of hitting over 100 mph using direct drive, the Zero SR offers spirited riders an edge in competitive riding. The only motorcycle in the lineup available in red, the tank section of the motorcycle is highlighted with a sophisticated “Zero SR” emblem and the tail section features the motor controller with a bold and elegantly designed heat sink.
2014 Zero SR Totalmotorcycle.com Key Features
Interested in torque and acceleration? Meet the Zero SR. With 106 ft-lbs of torque and capable of 0-60 mph in 3.3 seconds, the Zero SR is the fastest electric motorcycle that we have ever released.
2014 Zero SR Totalmotorcycle.com Features and Benefits
Game Changing Z-Force® Power Pack: 130+ Mi Range / 300,000+ Mi Lifetime
The 2014 Zero S leverages an advanced battery cell chemistry and configuration. Not only does the ZF11.4 power pack enable you to go beyond 130 miles, it is also designed to last the life of the motorcycle. The result of cutting edge research and development, each cell in the power pack is individually controlled and monitored at all times to ensure maximum health. The highly efficient onboard charger minimizes charge time and can work in parallel with Zero’s quick charge systems. What’s this all mean? Simply put, the Zero S is the leader for production electric motorcycles in acceleration, range, recharge time and longevity.
2014 Zero SR - Totalmotorcycle.com North America Specifications/Technical Details
US MSRP Price: $16,995 - $19,490 USD
Canada MSRP Price: See dealer for pricing in CDN
ZERO SR zf11.4 Totalmotorcycle.com
City 137 miles (220 km)
Highway, 55 mph (88 km/h) 85 miles (137 km)
» Combined 105 miles (169 km)
Highway, 70 mph (112 km/h) 70 miles (113 km)
» Combined 93 miles (149 km)
Max torque 106 ft-lb (144 Nm)
Max power 67 hp (50 kW) @ 4,000 RPM
Top speed (max) 102 mph (164 km/h)
Top speed (sustained) 85 mph (137 km/h)
Acceleration, 0-60 mph (0-100 km/h) 3.3 seconds
Type Z-Force® 75-7 passively air-cooled, high efficiency, radial flux, permanent high-temp magnet, brushless motor
Controller High efficiency, 660 amp, 3-phase brushless controller with regenerative deceleration
Est. pack life to 80% (city) 308,000 miles (496,000 km)
Power pack Z-Force® Li-Ion intelligent Totalmotorcycle.com
Max capacity 11.4 kWh
Nominal capacity 10.0 kWh
Charger type 1.3 kW, integrated
Charge time (standard) 7.9 hours (100% charged) / 7.4 hours (95% charged)
CHAdeMO charge time (accessory) 1.5 hours (100% charged) / 1 hour (95% charged)
Quick 2x charger time (accessory) 4.6 hours (100% charged) / 4.1 hours (95% charged)
Input Standard 110V or 220V
Transmission Clutchless direct drive
Final drive 132T / 30T, Poly Chain® GT® Carbon™ belt
Front suspension 43 mm inverted, aluminum slider forks with adjustable compression and rebound damping
Rear suspension Piggy-back reservoir shock with adjustable spring preload, compression and rebound damping
Front suspension travel 6.25 in (159 mm)
Rear suspension travel 6.35 in (161 mm)
Front brakes Nissin 2 piston hydraulic, 313x4 mm floating disc
Rear brakes J-Juan 1 piston hydraulic, 240x4.5 mm disc
Front tire 110/70-17
Rear tire 140/70-17
Front wheel 3.00x17
Rear wheel 3.50x17
Wheel base 55.5 in (1,410 mm)
Seat height 31.8 in (807 mm)
Rake 24.0 ° Totalmotorcycle.com
Trail 3.2 in (80 mm)
Frame 22 lb (10 kg)
Curb weight 407 lb (185 kg)
Carrying capacity 358 lb (162 kg)
Equivalent fuel economy (city) 462 MPGe (0.51 L/100 km)
Equivalent fuel economy (highway) 236 MPGe (1.00 L/100 km)
Typical cost to recharge $1.28
MSRP $16,995.00
Standard motorcycle warranty* 2 years
Power pack warranty* 5 years / 100,000 miles Totalmotorcycle.com
ZERO SR ZF11.4 +Power Tank Totalmotorcycle.com
City 171 miles (276 km)
Highway, 55 mph (88 km/h) 106 miles (171 km)
» Combined 131 miles (211 km)
Highway, 70 mph (112 km/h) 88 miles (141 km)
» Combined 116 miles (186 km)
Acceleration, 0-60 mph (0-100 km/h) 3.9 seconds
Controller High efficiency, 660 amp, 3-phase brushless controller with regenerative deceleration. Totalmotorcycle.com
Est. pack life to 80% (city) 385,000 miles (620,000 km)
Max capacity 14.2 kWh
Nominal capacity 12.5 kWh
Charge time (standard) 9.9 hours (100% charged) / 9.3 hours (95% charged)
Quick 2x charger time (accessory) 5.8 hours (100% charged) / 5.1 hours (95% charged)
Rear tire 140/70-17
Front wheel 3.00x17
Rear wheel 3.50x17
Rake 24.0 °
Frame 22 lb (10 kg)
Curb weight 452 lb (205 kg)
Carrying capacity 313 lb (142 kg), Totalmotorcycle.com
Typical cost to recharge $1.60
MSRP $19,490.00
Power pack warranty* 5 years / 100,000 miles, Totalmotorcycle.com
