For A LOT MORE photos and information click here: http://www.totalmotorcycle.com/motorcyc ... tal-GT.htm
2014 Royal Enfield Continental GT Cafe Racer on the Total Motorcycle Cool Wall
Rock on...
The Royal Enfield Continental GT. This is the lightest, fastest, most powerful Royal Enfield in production.
It’s a machine with a story, a nod to motorcycling's finest hour; a painstaking collaboration. It is also the best expression yet of a cultural phenomenon that has simply refused to fade away - the café racer.
Explore the motorcycle in its magnificence.
The standard 500cc Bullet engine has been increased to 535cc, and with a larger throttle body and hotter cam it boosts it to around 29HP. The new chassis, designed by Harris Performance, is sportier than the standard Bullet, and has a double down tube frame and longer swing arm. The suspension consists of a non-adjustable 38mm Gabriel fork and twin preload and rebound-adjustable Paioli shocks. A Brembo front brake and full-floating disc provide a serious upgrade in stopping power.
2014 Royal Enfield Continental GT Cafe Racer Totalmotorcycle.com Features and Benefits
The Royal Enfield Continental GT is the lightest, fastest, most powerful Royal Enfield in production. A machine with a story, a nod to motorcycling’s finest hour; a painstaking collaboration. It is also the best expression yet of a cultural phenomenon that has simply refused to fade away - the café racer.
2014 Royal Enfield Continental GT Cafe Racer - Totalmotorcycle.com North American Specifications/Technical Details
US MSRP Price: $5,990 USD
Canadian MSRP Price: $ See Dealer for pricing in CDN
Engine Single Cylinder, 4-Stroke, Spark Ignition, Air Cooled, OHV
Cubic Capacity 535 cc
Bore x Stroke 87mm x 90mm
Compression Ratio 8.5:1
Maximum Power 29.1 bhp (21.4 kW) @ 5100 rpm
Maximum Torque 44 Nm @ 4000 rpm
Ignition System Digital Electronic Ignition
Clutch Wet, Multi-Plate
Brakes- Front Brembo 300mm Floating disc, 2-Piston floating caliper
Brakes- Rear 240mm Disc, Single piston floating caliper
Tires - Front 100/90-18, 56 H Pirelli Sport Demon
Tires - Rear 130/70-18, 63 H Pirelli Sport Demon
Dimension - L x W x H 81in x 30in x 31in
Wheel Base 54 inches
Ground Clearance 5.5 inches
Weight (Wet) 412 lbs
