For A LOT MORE photos and information click here: http://www.totalmotorcycle.com/motorcyc ... Vultus.htm
![Image](http://cdn-0.totalmotorcycle.com/motorcycles/2014models/2014-Honda-NM4-Vultus2-small.jpg)
![Image](http://cdn-0.totalmotorcycle.com/motorcycles/2014models/2014-Honda-NM4-Vultus4-small.jpg)
2014 Honda NM4 Vultus
Japanimation on two-wheels...
A ground-breaking machine inspired by the desire to establish a unique riding experience and an identity not bound by standard motorcycle design, with strong echoes of futuristic bikes seen in Japanese movies. Created by a young design team who remained true to their original concept at every stage through to production, the NM4 Vultus brings radical style to the streets, with function from the future for a new breed of rider.
Honda announces the new NM4 Vultus, a ground-breaking machine inspired by futuristic machines seen in the anime and manga television and film styles, known collectively as “Japanimation”.
Created by a young design team who remained true to their original concept at every stage through to production, the NM4 Vultus brings radical style to the streets, with function from the future for a new breed of rider. The NM4 represents a machine capable of crossing traditional two-wheeled lines and reaching out to a wider audience.
Vultus is Latin for appearance, expression – or face. The NM4 Vultus, with its LED lights, future-shock style and stealth bomber silhouette presents a look that will not have been seen in any cityscape this side of an anime movie…
Underneath the brooding menace is a rock-solid chassis and engine package. Packed with low-friction technology, its 745cc twin-cylinder engine is canted forward, creating space and a low centre of gravity. Delivering strong low and mid-range power and torque for smooth acceleration coupled with excellent fuel economy, it’s also equipped as standard with Dual Clutch Transmission (DCT), giving the rider options between automatic twist-and-go D and S mode – plus trigger-operated computer game-style manual MT mode. Intuitive and easy to use, it adds to the futuristic appeal of the NM4 Vultus and is the perfect complement to the engine’s gutsy, usable performance.
2014 Honda NM4 Vultus - http://www.Totalmotorcycle.com UK/European Specifications/Technical Details
European MSRP Price: See Dealer for Pricing in GBP
ENGINE (http://www.totalmotorcycle.com)
Type Liquid-cooled 4-stroke 8-valve, SOHC parallel 2-cylinder
Displacement 745cc
Bore ´ Stroke 77mm x 80mm
Compression Ratio 10.7 : 1
Max. Power Output 40.3kW @ 6,250rpm (95/1/EC)
Max. Torque 68Nm @ 4,750rpm (95/1/EC)
Oil Capacity 3.9 litres
FUEL SYSTEM
Carburation PGM-FI electronic fuel injection
Fuel Tank Capacity 11.6 litres
Fuel Consumption 28.4km/l (WMTC mode-Tested in D-Mode) (http://www.totalmotorcycle.com)
ELECTRICAL SYSTEM
Starter Electric
Battery Capacity 12V/11.2AH
ACG Output 450W/5000rpm
DRIVETRAIN
Clutch Type Wet multiplate hydraulic 2-clutch
Transmission Type 6-speed Dual Clutch Transmission
Final Drive Chain
FRAME (http://www.totalmotorcycle.com)
Type Diamond; steel pipe
CHASSIS
Dimensions (L´W´H) 2380mm x 933mm x 1170mm
Wheelbase 1645mm
Caster Angle 33°
Trail 110mm
Seat Height 650mm
Ground Clearance 130mm
Kerb Weight 245kg
SUSPENSION
Type Front 43mm telescopic fork, 125mm stroke
Type Rear Monoshock damper, Pro-Link swingarm, 100mm travel (http://www.totalmotorcycle.com)
WHEELS
Type Front Multi-spoke cast aluminium
Type Rear Multi-spoke cast aluminium
Rim Size Front 18M/C x MT3.50
Rim Size Rear 17M/C x MT6.25
Tyre front 120/70 ZR18
Tyre rear 200/50 ZR17
BRAKES
ABS System Type 2 channel ABS
Type Front 320mm single wavy hydraulic disc with 2-piston caliper and sintered metal pads
Type Rear 240mm single wavy hydraulic disc with single-piston caliper and resin mold pads
INSTRUMENTS & ELECTRICS
Instruments Digital speedometer, (http://www.totalmotorcycle.com) igital bar-type tachometer, clock, bar-type fuel meter, two trip meters, gear position indicator, outside air temperature gauge and coolant temperature warning light.
Security System HISS
Headlight LED
Taillight LED
