For MORE information and Photos click here: http://www.totalmotorcycle.com/motorcyc ... 000ABS.htm
2014 Kawasaki Z1000 ABS
CALL OF THE WILD
Sculpted bodywork brings the aggressive and unique sugomi inspired Z design to the next level, stripping off all unnecessary flourishes to boldly highlight brutal functionality. Enhancing the riding impact, the new engine and chassis settings deliver a stiffer, more direct ride transforming the Z1000 into the market’s most radical Supernaked.
The "it" factor is hard to describe, but you always know it when you see it. Likewise, the new 2014 Kawasaki Z1000 has a hard-to-define "streetfighter" style that is impactful enough to ensure everyone knows they're seeing something special. In a significant departure from the concealing bodywork of its sportbike predecessor, the new Z1000 strips-off unnecessary covers and bodywork to expose the superior functionality of its parts.
The Kawasaki Z design language has been elevated to a higher level with the new Z1000's "Sugomi" styling. From its seductively sculpted shapes invoking a crouching predator and painstaking details like its special "Z" logo ignition keys, machined aluminum steering stem bolt, and intricately textured "Z" motif seat cover, to the tighter tolerances of its high-quality components and bodywork, the dramatic result has a very special feel that helps set the stage for the excitement to follow!
For 2014, Kawasaki engineers concentrated on making the Z1000 more potent and capable than ever!
2014 Kawasaki Z1000 ABS - Totalmotorcycle.com USA Specifications/Technical Details
US MSRP Price: $11,999 USD
Canada MSRP Price: $13,299 CDN
Engine: Four-stroke, liquid-cooled, DOHC, four valves per cylinder, inline-four
Displacement: 1,043cc
Bore x stroke: 77.0 x 56.0mm
Compression ratio: 11.8:1
Fuel injection: DFI® with four 38mm Keihin throttle bodies, oval sub-throttles
Ignition: TCBI with digital advance
Transmission: Six-speed
Final drive: X-ring chain
Rake / trail: 24.5 degrees / 4.0 in.
Frame type: Aluminum Backbone
Front tire: 120/70 ZR17
Rear tire: 190/50 ZR17
Wheelbase: 56.5 in.
Front suspension / wheel travel: 41 mm inverted SFF-BP fork with stepless compression and rebound damping and spring preload adjustability / 4.7 in.
Rear suspension / wheel travel: Horizontal monoshock with stepless rebound damping, remotely adjustable spring preload / 4.8 in.
Front brakes: Dual 310mm petal-type rotors with radial-mount four-piston monobloc calipers and ABS
Rear brake: Single 250mm petal-type rotor with single-piston caliper and ABS
Overall length: 80.5 in.
Overall width: 31.1 in.
Overall height: 41.5 in.
Seat height: 32.1 in.
Curb weight: 487.3 lbs.
Fuel capacity: 4.5 gal.
Color choices: Golden Blazed Green / Metallic Graphite Gray
