Forum upgrade from phpBB 3.1.1 to 3.1.3, latest version.
Years Riding: 32
Enjoy!
...and for those interested, here are the upgrades/changes:
Changes since 3.1.3-RC1
Bug
•[PHPBB3-12933] - The search operator for partial matches does not work
•[PHPBB3-13544] - Migrations' "permission.permission_unset" deletes all permissions instead of just the one stated
•[PHPBB3-13556] - Translated exceptions from file_downloader are handled incorrectly
•[PHPBB3-13557] - Migrations for 3.0.13 and PL1 are missing
Task
•[PHPBB3-13553] - Controller helper needs a message handler to replace error handler
Changes since 3.1.2
Security
•[PHPBB3-13519] - Correctly validate imagick path as path and not string
Bug
•[PHPBB3-9100] - Inline attachments are not being inserted at the cursor
•[PHPBB3-11613] - Cookies do not work for netbios domain
•[PHPBB3-12089] - Make HTTP status code error messages more informative
•[PHPBB3-12642] - Custom profile field isn't displayed
•[PHPBB3-12698] - Replace all instances of magic numbers with constants in javascript
•[PHPBB3-12866] - Wrong profile field validation options
•[PHPBB3-13098] - Repair Yahoo contact field
•[PHPBB3-13192] - confirm_box() action contains app.php when enable_mod_rewrite is set
•[PHPBB3-13238] - \phpbb\db\migration\data\v310\mysql_fulltext_drop tries to drop non existent indexes
•[PHPBB3-13272] - Changed Files packages do not include vendor directory
•[PHPBB3-13282] - PostgreSQL error when creating boolean/dropdown custom profile fields
•[PHPBB3-13302] - ACP links to docs need to be updated to 3.1 URLs
•[PHPBB3-13307] - develop/mysql_upgrader.php does not work anymore
•[PHPBB3-13319] - Icons/smilies table improperly formed when no images present
•[PHPBB3-13346] - Missing space in posting_editor.html
•[PHPBB3-13357] - LOG_MOVED_TOPIC Language var missing
•[PHPBB3-13358] - Add class for retrieving remote file data
•[PHPBB3-13362] - The whole cache dir (excluding the .htaccess and index.html files) should be ignored by git
•[PHPBB3-13366] - Dynamic config for "plupload_last_gc" is static
•[PHPBB3-13381] - Code Sniffer complains about 3.1.2 migration
•[PHPBB3-13385] - Add free result after running update query in $config->set_atomic()
•[PHPBB3-13391] - subsilver2 poll options must have a setting of 1 when editing a post
•[PHPBB3-13393] - Invalid parameters passed to call_user_func_array in version_helper.php
•[PHPBB3-13396] - Multibyte chars cause attachment upload to fail
•[PHPBB3-13400] - Add a new message for high server loads during search
•[PHPBB3-13405] - A typo in style_update_p1.php migration may prevent updating in some circumstances
•[PHPBB3-13406] - ADD INDEX syntax may cause an error in earlier MySQL versions
•[PHPBB3-13420] - Prune users bug - filter all with 0 posts
•[PHPBB3-13427] - Add template events to MCP front before/after each list
•[PHPBB3-13431] - Wrong margin-left for RTL sites in Internet Explorer mobile view
•[PHPBB3-13432] - Migrator module tool does not add the needed module language file
•[PHPBB3-13441] - functions_convert fails to set global moderators default group
•[PHPBB3-13442] - UTF-8 symbols for database host
•[PHPBB3-13448] - \phpbb\messenger->template can't find email templates in extensions
•[PHPBB3-13453] - Sort params in Canonical URL
•[PHPBB3-13470] - Mass email says "user doesn't exist" when all users is selected
•[PHPBB3-13486] - Call to undefined method phpbb\db\driver\factory::sql_escpape() on database update
•[PHPBB3-13489] - Allow the migrations to use the DI container
•[PHPBB3-13490] - Unicode chars are broken in edit message after preview
•[PHPBB3-13492] - Custom BBCode URL tokens do not support IDN
•[PHPBB3-13504] - "Array" is displayed when searching, or when unanswered posts or active topics are selected
•[PHPBB3-13507] - Large images in posts can cause horizontal scrollbars
•[PHPBB3-13511] - The "Unused Use" Sniff is broken
•[PHPBB3-13530] - Fix undefined variables in migrations and tests
•[PHPBB3-13534] - Non-existent path in attachment settings causes travis failure
•[PHPBB3-13543] - Slow tests fail on 3.1 and 3.2
Improvement
•[PHPBB3-11033] - FULLTEXT_SPHINX_NO_CONFIG_DATA references unrequired field
•[PHPBB3-12567] - [proSilver] - viewtopic_body.html: Change 'back2top' anchor in to '#top'
•[PHPBB3-12926] - Support for IDN (IRI)
•[PHPBB3-13266] - Enabling twig dump function if DEBUG is defined
•[PHPBB3-13306] - Add error level to the error collector
•[PHPBB3-13312] - [event] - Add core event to the mass email form
•[PHPBB3-13368] - Add the forum_data var to the core.viewforum_get_topic_ids_data event
•[PHPBB3-13370] - Add ability to call class methods more easily in the convertor framework
•[PHPBB3-13389] - Replace pattern with path in routing.yml
•[PHPBB3-13402] - Code Sniffer, unused use, check the function doc blocks
•[PHPBB3-13409] - Add event to modify search parameters before searching
•[PHPBB3-13419] - Add template event at the end of the file
•[PHPBB3-13422] - Add new events in save custom cookies and set custom ban type
•[PHPBB3-13428] - Add core events to memberlist.php for teampage
•[PHPBB3-13430] - Add event for modifying prune SQL
•[PHPBB3-13435] - Add core event to modify submit_post() sql data
•[PHPBB3-13437] - [Template] - viewtopic_body_post_author_before/after
•[PHPBB3-13439] - [event] - Add event to run code at beginning of ACP users overview
•[PHPBB3-13440] - [event] - Add event to process when a user fails a login attempt
•[PHPBB3-13449] - Add viewforum.php core event after the topic data has been assigned to template
•[PHPBB3-13466] - Add bbcode_uid and bitfield to event core.message_parser_check_message
•[PHPBB3-13478] - Add core event core.bbcode_cache_init_end
Sub-task
•[PHPBB3-13141] - Add an event to allow applying additional permissions to MCP access besides f_read
•[PHPBB3-13146] - Add an event to allow changing the result of calling get_forums_visibility_sql()
•[PHPBB3-13147] - Add an event to change get_global_visibility_sql()'s results
•[PHPBB3-13148] - Add an event to creating a final way to modify edit logs output
•[PHPBB3-13154] - Add an event to edit user list for notifications
•[PHPBB3-13158] - Add an event to allow adding extra auth checks when the user is posting
•[PHPBB3-13159] - Add an event to allow extra auth checks when reporting posts
•[PHPBB3-13160] - Add an event to viewtopic before viewing permissions
Task
•[PHPBB3-12924] - Meta tags should be self-closing
•[PHPBB3-13528] - Boolean checkbox profile fields display "1" instead of selected value
Changes since 3.1.1
Security
•[SECURITY-171] - Version helper does not properly escape version info
•[SECURITY-169] - AJAX request with unexpected referrer causes infinite loop
Bug
•[PHPBB3-10442] - XHTML is invalid when a forum link without redirect counter is present
•[PHPBB3-10744] - Prevent user from installing styles with reserved directory names
•[PHPBB3-11863] - User registration settings show incorrectly as disabled when board-wide emails are disabled
•[PHPBB3-12703] - Notification System sends exact same SQL query multiple times
•[PHPBB3-13083] - Language correction in NO_ENTRIES in acp_logs
•[PHPBB3-13100] - Don't display "delete reason" dialog for shadow-topics
•[PHPBB3-13193] - Post counts in Private Messages should link to the user's posts
•[PHPBB3-13197] - Group Avatar not deleted from users
•[PHPBB3-13204] - Login flood control error supresses incorrect credential error
•[PHPBB3-13209] - Boolean (Yes/No) custom profile field doesn't show given name
•[PHPBB3-13216] - Datetime tests fail randomly
•[PHPBB3-13228] - "Code: Select all" font-size too big in Private Messages
•[PHPBB3-13239] - Can´t upload Attachments on iOS
•[PHPBB3-13241] - Topics are being duplicated in multipage forums
•[PHPBB3-13242] - Validation error in Contact a Board Administrator
•[PHPBB3-13243] - Debug error when clicking Re-check all versions on ACP manage extensions page
•[PHPBB3-13251] - Database password containing special characters no longer accepted after upgrade to 3.1.0
•[PHPBB3-13253] - MCP queue link in active topics search is missing
•[PHPBB3-13265] - "Edit profile" link on view-own-profile page should only show if user has permission to edit
•[PHPBB3-13270] - Upgrading from 3.0.12 to 3.1.1 does not display moderator soft delete permissions
•[PHPBB3-13277] - Move Up & Down does not take work in Internet Explorer
•[PHPBB3-13280] - $user->page['page'] - is invalid resulting in confirm_box() not working correctly
•[PHPBB3-13284] - Message body not included in email topic message
•[PHPBB3-13298] - Use mysql_free_result to free result sets which were requested using mysql_query()
•[PHPBB3-13300] - Jabber field still shown in profile when feature is disabled
•[PHPBB3-13301] - Apache Authentication is probably broken
•[PHPBB3-13303] - Migrator caught in loop calculating dependencies
•[PHPBB3-13315] - Upgrade from 3.0.12 to 3.1.1 resets CAPTCHA selection
•[PHPBB3-13316] - reCAPTCHA does not work on secured connection
•[PHPBB3-13318] - login_username doesn't have multibyte parameter set to true
•[PHPBB3-13323] - posting.php can pass invalid auth option to acl_get()
•[PHPBB3-13332] - Insufficient information passed to password drivers for converted boards
•[PHPBB3-13337] - Mark subforums read triggers error if subforums contain no topics
•[PHPBB3-13338] - Some tests fail when run on their own
•[PHPBB3-13342] - 310/captcha_plugins migration changes recaptcha to nogd
•[PHPBB3-13349] - Incorrect entities used for breadcrumb separator in CSS
•[PHPBB3-13354] - Unknown column 'topic_logs' in 'where clause' when deleting topic log in MCP
•[PHPBB3-13376] - deregister_globals() does not work correctly when $_COOKIE['GLOBALS'] is specified
Improvement
•[PHPBB3-12681] - Cache the compiled routes and dump the url_generator
•[PHPBB3-12885] - Wrong index page title when using Board Index text
•[PHPBB3-13023] - [event] - Add Event posting_editor_buttons_custom_tags_before
•[PHPBB3-13133] - Allow @vendor_extname in INCLUDECSS
•[PHPBB3-13182] - [event] - Add posting.php core event to allow modifying the message before parsing
•[PHPBB3-13220] - [event] - Add template events to memberlist_search.html
•[PHPBB3-13290] - [event] - Add template event index_body_forumlist_body_after
•[PHPBB3-13294] - [event] - Add message_parser.php core event for additional message handling before parsing
•[PHPBB3-13297] - Add unicode modifier to url/email regular expression patterns
•[PHPBB3-13309] - [event] - Add ACP template event acp_email_options_after
•[PHPBB3-13310] - [event] - Add core event core.acp_email_modify_sql
•[PHPBB3-13326] - Add viewtopic_url variable to a viewtopic event
•[PHPBB3-13328] - [event] - Add event core.mcp_view_forum_modify_sql
•[PHPBB3-13347] - [event] - Add new template events to acp_forums.html
New Feature
•[PHPBB3-12962] - Use phantomjs and webdriver for UI testing
Task
•[PHPBB3-13324] - Composer no longer downloads sami/sami and fabpot/goutte
•[PHPBB3-13325] - Make installing dependencies for tests more user friendly or optional
•[PHPBB3-13331] - Sami run as part of phing MUST NOT switch branches
2023 Motorcycle Model Guides
Re: Forum upgrade from phpBB 3.1.1 to 3.1.3, latest version.
#2 Unread post by dr_bar »
Just a dumb question, why do links take us away from the site, instead of opening a new page/ window?
Years Riding: 32
dr_bar wrote:Just a dumb question, why do links take us away from the site, instead of opening a new page/ window?
Hmmm, that's a good question. I check and I do not have the option to "open in a new window"... Let me ask my host if they know a trick/tip.
e1_zx-9r
My Motorcycle: 2000 & 2002/Kawasaki ZX-9Rs
#4 Unread post by e1_zx-9r »
Not really a fan of the new format or should I say theme. Not terribly into tradition, but the new them seems more suited for a 640 x 480 13" monochrome monitor than any widescreen display on the market today. Without zooming in using the browser, it appears that 1/3 of the screen is empty gray bars on both sides. Why the reduction?
Some of these PHP upgrades allow users to control theme. If that was an option, to change personal theme preference, that would be great. But I'd like to see the forum default to something a little wider. Maybe blow it way out to 1024 x 768. I know that's more like the standard from 2004, but this format feels like I've been sent back to the early 1990s.
