For MORE information and Photos click here: http://www.totalmotorcycle.com/motorcyc ... 1100RR.htm
2015 Aprilia Tuono V4 1100RR
THE FASTEST AND SPORTIEST NAKED EVER IS NOW EVEN BETTER AND BECOMES A TRUE COMPLETE WEAPON FOR THE ROAD AND FOR THE TRACK...
DIRECT DESCENDANT OF THE RSV4, THE BIKE THAT WON SEVEN WORLD SBK CHAMPIONSHIP TITLES, THE APRILIA TUONO V4 1100 IS ADRENALINE IN ITS PUREST STATE
THE PERFORMANCE OF ITS UNRIVALLED, REVAMPED V4 HAS BEEN INCREASED TO 1100 CC AND 175 HP; MORE EFFICIENT TO RIDE THANKS TO ITS REVAMPED CHASSIS AND THE FURTHER DEVELOPMENT OF THE ALREADY EXCEPTIONAL aPRC ELECTRONICS SYSTEMS PACKAGE, BUT AT THE SAME TIME MORE CONVENIENT AND EVEN SAFER FOR ROAD USE
THERE ARE TWO MODELS IN THE RANGE - RR AND FACTORY - CHARACTERISED BY A NEW LOOK AND DISTINCTIVE FEATURES, BUT WITH THE TYPICAL CHARACTER OF THE TUONO HERITAGE. AND FOR THE FIRST TIME TELEMETRY ARRIVES, THANKS TO THE V4-MP PLATFORM
2015 Aprilia Tuono V4 1100RR - http://www.Totalmotorcycle.com USA Specifications/Technical Details
US MSRP Price: $14499 USD
Canada MSRP Price: $14995 USD
Engine type Aprilia longitudinal 65° V4 cylinder, 4-stroke, liquid cooled engine with dual overhead cam (DOHC) and four valves per cylinder
Fuel Unleaded gasoline
Bore and stroke 81 x 52.3 mm
Total engine capacity 1077 cc
Maximum power at crankshaft 175 HP (129 kW) at 11,000 rpm
Maximum torque at crankshaft 120 Nm at 9,000 rpm
Fuel system Airbox with front dynamic air intakes.
4 Weber-Marelli 48-mm throttle bodies with 4 injectors and latest generation Ride-by-Wire engine management.
Choice of three different engine maps selectable by the rider with bike in motion: T (Track), S (Sport), R (Road)
Ignition Magneti Marelli digital electronic ignition system integrated in engine control system, with one spark plug per cylinder and "stick-coil"-type coils
Starting Electrical
Exhaust 4 into 2 into 1 layout, single oxygen sensor, lateral single silencer with ECU-controlled bypass valve and integrated trivalent catalytic converter (Euro 3)
Alternator Flywheel mounted 450 W alternator with rare earth magnets
Lubrication Wet sump lubrication system with oil radiator and two oil pumps (lubrication and cooling)
Gearbox 6-speed cassette type gearbox
1st: 39/15 (2,600)
2nd: 33/16 (2.063)
3rd: 34/20 (1,700)
4th: 32/22 (1,455)
5th: 34/26 (1,308)
6th: 33/27 (1,222)
Gear lever with Aprilia Quick Shift electronic system (aQS)
Clutch Multiplate wet clutch
Primary drive Straight cut gears and integrated flexible coupling, drive ratio: 73/44 (1,659)
Secondary drive Chain: Drive ratio: 42/16 (2,625)
Traction management
aPRC System (Aprilia Performance Ride Control), which includes Traction Control (aTC), Wheelie Control (aWC), Launch Control (aLC), all of which can be configured and deactivated independently.
Frame Aluminium dual beam chassis with pressed and cast sheet elements.
Sachs steering damper
Front suspension Upside-down "one by one" Sachs fork, Ø 43 mm stanchions. Forged aluminium radial calliper mounting bracket. Completely adjustable spring preload and hydraulic compression and rebound damping. Wheel travel: 120 mm
Rear suspension Double braced aluminium swingarm; mixed low thickness and sheet casting technology.
Sachs monoshock with piggy-back, fully adjustable in: spring preload, hydraulics in compression and rebound [Öhlins Racing monoshock with piggy-back, fully adjustable in: spring preload, wheelbase length, hydraulics in compression and rebound]. APS progressive linkages. Wheel travel: 130 mm
Brakes Front: Dual 320 mm floating stainless steel discs with lightweight stainless steel rotor with 6 studs [aluminium flange] Brembo M432 monobloc radial callipers with 4 Ø 32 mm opposing pistons. Sintered pads. Axial pump master cylinder and metal braided brake hoses.
Rear: 220 mm diameter disc; Brembo floating calliper with two Ø 32 mm separate pistons. Sintered pads. Master cylinder with built in reservoir and metal braided hose.
Bosch 9MP ABS, adjustable to 3 maps equipped with RLM (can be disabled).
Wheel rims Cast aluminium wheels with 3 split spoke design.
Front: 3.5"X17"
Rear: 6.00"X17"
Tyres Radial tubeless.
Front: 120/70 ZR 17
Rear: 190/55 ZR 17 (alternative: 190/50 ZR 17; 200/55 ZR 17)
Dimensions
Saddle height: 825 mm
Trail: 99.7 mm
Steering angle: 24.7°
Kerb weight 184 kg *
Fuel tank 18.5 litres (4-litre reserve included)
*Dry weight, without battery and fluids.
