For MORE information and Photos click here: http://www.totalmotorcycle.com/photos/2 ... tTrain.htm
![Image](http://cdn-0.totalmotorcycle.com/photos/2002models/2002-Harley-Davidson-FXSTB-FXSTBINightTrain.jpg)
2001 Harley-Davidson FXSTB/FXSTBI Night Train on Totalmotorcycle.com
FEATURES
Harley® riders have always had a special place in their hearts for the color black. The black-on-black Night Train™ has a profile that pushes the limit. Sink deep into the depths of its low custom seat. Settle in behind the stainless drag bars on top of six-inch risers, and a wide raked fork straddling a 21-inch laced wheel. The hefty, one-piece tank is settled over the bike's new Twin Cam 88B™ engine, which is blacked out, using wrinkle black finishes.
-Rigid mount, 1450cc Twin Cam 88B™ balanced engine
-Black powdercoated engine with wrinkle black and texture black covers
-Laced front wheel, disc rear wheel
-Badlander seat
-Drag bars
-Black tank console, rear fender supports, air cleaner, and oil tank
Vehicle specifications and features may vary from country to country depending on local laws, and some models are not available in certain countries.
Totalmotorcycle.com Specifications:
Engine Type: 1449 cc, 4-Stroke, Air Cooled, V-Twin
Engine Bore and Stroke: 95.3 mm x 101.6 mm
Valves 2 valves/cylinder
Claimed Horsepower: 63 hp (47 kW) @ 5300 rpm
Maximum Torque: 106 Nm (78.2 ft. lbs) @ 3200 rpm
Transmission type: 5 speed
Final Drive: Belt
Tire - Front: 80/90-19
Tire - Rear: 130/90-16
Brakes - Front: single 292 mm disc with 4-piston calipers
Brakes - Rear: single 292 mm disc with 4-piston calipers
Seat Height: 638 mm (25.1 inches)
Wheelbase 1694 mm (66.7 inches)
Fuel Capacity: 18,9 l - 1,9 l
Dry Weight (without fluids): 305 kg (672.4 pounds)
