For MORE information and Photos click here: http://www.totalmotorcycle.com/motorcyc ... Carbon.htm
![Image](http://cdn-0.totalmotorcycle.com/motorcycles/2016/2016-Ducati-Diavel-Carbon1-small.jpg)
![Image](http://cdn-0.totalmotorcycle.com/motorcycles/2016/2016-Ducati-Diavel-Carbon2-small.jpg)
2016 Ducati Diavel Carbon
The most powerful Ducati naked ever...
The 2016 version of the Diavel Carbon is now more assertive than ever thanks to all-new graphics and several new technical-aesthetic features.
The Diavel is a unique, different, innovative and brave bike. Strengthened by a style that has literally won over the world’s motorcycle community, it has opened new horizons for the Ducati brand.
Muscular and with a strong presence, the Diavel dominates the road while remaining as lightweight and agile as other Ducati models.
The latest generation Testastretta 11° Dual Spark engine with ABS, Ducati Traction Control, Ducati Riding Modes and typical Ducati agility guarantee an exciting but safe riding experience. Its 162 hp and weight of just 205 kg* (452 lb.), together with its exclusive design, make the Diavel a comfortable and sporty lifestyle motorcycle.
The new Asphalt Grey colour that characterises this new 2016 version elegantly balances with the visible carbon, the red stripes and the Dark Chrome paintwork on the frame. The exclusive forged wheels with exposed machined finish, enhance the muscular design of the bike. Other new features on the 2016 version of the Diavel Carbon include the exhaust manifolds with Zircotec ceramic coating. This type of coating renders the exhaust system more sophisticated and technological; the system is also equipped with brushed-effect stainless steel silencer covers. In addition, the bike boasts a totally redesigned seat with new and exclusive trim.
In addition to the new Carbon version, the Diavel will also be available in the total black Dark Stealth version, with matt black tank and black frame and wheels.
With the 162 hp Testastretta engine and its incredible handling, the Diavel waiting for you to tell your unforgettable story.
The new Diavel Carbon exemplifies the distinctive style and sporty soul of the Diavel with high-quality, light-weight components. Clad with carbon fiber and forged wheels, weight is reduced to just 205 kg, only further enhancing the performance of this extraordinary motorcycle.
2016 Ducati Diavel Carbon - http://www.Totalmotorcycle.com USA Specifications/Technical Details
US MSRP Price: $ See Dealer for pricing in USD
Canada MSRP Price: $ See Dealer for pricing in CDN
Engine
Type
Testastretta 11° L-Twin, 4 Desmodromically actuated valves per cylinder, liquid cooled
Displacement
1198.4cc
Bore x Stroke
106 x 67.9mm
Compression ratio
12.5:1
Power
119 kW (162 hp) @ 9,250 rpm
Torque
130.5 Nm (96.2 lb-ft) @ 8,000 rpm
Technical data referring to power and torque was measured on an engine test stand at Ducati.
Fuel injection
Electronic fuel injection, elliptical throttle bodies, fully ride-by-wire controlled
Exhaust
Stainless steel silencer with brushed steel outer cover; http://www.Totalmotorcycle.com, catalytic converter and 2 lambda probes, manifolds coated with black ceramic Zircotec.
Transmission
TOP
Gearbox
6 speed
Primary drive
Straight cut gears, ratio 1.84:1
Ratio
1=37/15 2=30/17 3=27/20 4=24/22 5=23/24 6=22/25
Final drive
Chain drive; 15 tooth front sprocket, 43 tooth rear sprocket
Clutch
Slipper and self-servo wet multiplate clutch with hydraulic control
Chassis
Frame
Tubular steel Trellis frame with Dark Chrome paint
Front suspension
Fully adjustable 50 mm usd fork with DLC-treatment
Front wheel
Marchesini forged and machined 10-spoke 3.50 x 17
Front Tyre
120/70 ZR 17 Pirelli Diablo Rosso II
Rear suspension
Fully adjustable rear shock with progressive linkage. Remote spring preload adjustment. Single-sided aluminium swingarm
Rear wheel
Marchesini forged and machined 10-spoke 8.00 x 17
Rear tyre
240/45 ZR17 Pirelli Diablo Rosso II
Front wheel travel
120mm (4.7in)
Rear wheel travel
120mm (4.7in)
Front brake
2 x 320 mm semi-floating discs, radially attached Brembo Monobloc 4-piston callipers with ABS as standard equipment
Rear brake
265mm disc, 2-piston floating calliper ABS as standard equipment
Instrumentation
Handlebar mounted instrumentation with LCD display: speed, rpm, time, coolant temp. Warning lights for: Neutral, turn signals, high-beam, rev-limit, DTC intervention, ABS status, oil pressure, fuel reserve. Tank mounted instrumentation with TFT colour display: gear selected, http://www.Totalmotorcycle.com, air temp, battery voltage, trips 1 & 2, fuel reserve trip, average and actual fuel consumption and speed, trip time, scheduled maintenance. Full status and/or management of Riding Modes, DTC, RbW and ABS.
Dimensions and weight
Dry weight
205kg (452lb)
Weight data refers to the dry weight of the motorcycle without battery, lubricants and coolants for liquid-cooled models.
Wet weight (KERB)
234kg (516lb)
Kerb weights indicate total bike weight with all operating consumable liquids and a fuel tank filled to 90% of capacity (as per EC standard 93/93).
Seat height
770mm (30.3in)
Wheelbase
1590mm (62.6in)
Rake
28°
Trail
130mm (5.1in)
Fuel tank capacity
17l - (4.5 US gal)
Number of seats
Dual seat
Equipments
Standard Equipment
Riding Modes, Power Modes, Ducati Safety Pack (ABS + DTC), RbW, Hands-Free, full-LED headlight, front turnsignals with guidelights, carbon fibre components
