For MORE information and Photos click here: http://www.totalmotorcycle.com/motorcyc ... -Force.htm
![Image](http://cdn-0.totalmotorcycle.com/motorcycles/2016/2017-Suzuki-SV650a-small.jpg)
![Image](http://cdn-0.totalmotorcycle.com/motorcycles/2016/2017-Suzuki-SV650c-small.jpg)
V-TWIN POWER FOR THE STREET...
For 2017, Suzuki introduces a new version of an iconic motorcycle that embodies the sporty personality that only a lively, mid-sized V-twin roadster can deliver. The new SV650 ABS* has a polished powerplant that provides increased performance with low emissions and outstanding fuel economy, mated to refined trim and lightweight chassis that delivers a sporty, exciting ride. Like its predecessors, the 2017 SV650 ABS promises to have the sparkling performance, style and value that a broad range of riders will enjoy.
That’s why we've built the new SV650 with a punchy V-Twin engine and light weight chassis. The new SV650 is the bike that will make your daily commutes or weekend blasts unforgettable.
*Depending on road surface conditions, such as wet, loose, or uneven roads, braking distance for an ABS-equipped vehicle may be longer than for a vehicle not equipped with ABS. ABS cannot prevent wheel skidding caused by braking while cornering. Please drive carefully and do not overly rely on ABS.
2017 Suzuki SV650 http://www.Totalmotorcycle.com Key Features
Liquid cooled, 645cc, 4-stroke, DOHC, V-twin engine delivers increased performance.
Refined EFI system with Low RPM Assist makes take offs smooth and pleasant.
Trellis-style frame constructed of high-strength steel tubes contributes to the motorcycle’s lower weight and trim chassis.
Slim bodywork is aesthetically pleasing while aiding comfort and maneuverability.
V-Twin Excitement
What started in 1999 as a motorcycle built to deliver “V-Twin fun”, the Suzuki SV650 quickly became renowned the world over. Not only was this a motorcycle with universal appeal, but it was well-suited to urban roads and was right at home on the racetrack too.
Presenting the newest version of the SV650, it comes complete with the latest Suzuki innovations and will set the bar even higher for V-Twin fun and performance.
The SV650’s V-Twin comes loaded with capabilities and exudes personality, to make sure your daily commutes or weekend blasts are an unforgettable ride. No matter if you’ve just gained your licence or you’ve been riding for years, the SV650’s light weight and ultra-slim profile make you want to take to the road again and again.
2017 Suzuki SV650 - http://www.Totalmotorcycle.com USA Specifications/Technical Details
MSRP Price: $TBA USD
Engine
Engine 645 cc, 4-stroke, 2-cylinder, liquid-cooled, DOHC, 90-degree V-Twin
Bore x Stroke 3.19 in x 2.46 in (81.0 x 62.6mm)
Compression Ratio 11.2: 1
Fuel System Fuel injection
Starter Electric
Lubrication Wet sump
Drive Train
Transmission 6-speed, constant mesh
Final Drive Chain
Chassis
Suspension Front Telescopic, coil spring, oil damped
Suspension Rear Link type, coil spring, oil damped, spring preload 7-step adjustable
Brakes Front Twin 2-piston calipers, 290 mm discs
Brakes Rear Single 1-piston caliper, 240 mm disc
Tires Front 120/70ZR17M/C (58W), tubeless
Tires Rear 160/60ZR17M/C (69W), tubeless
Fuel Tank Capacity 3.8 US gal (14.5 L) / 3.6 US gal (13.8 L) CA model
Color Pearl Mira Red & Pearl Glacier White
Overall Length 2140 mm (84.2 in.)
Overall Width 760 mm (29.9 in.)
Curb Weight 195 kg (429.9 lbs.) / 197 kg (434.3 lbs.) ABS model
Wheelbase 1445 mm (56.9 in.)
Ground Clearance 135 mm (5.3 in.)
Seat Height 785 mm (30.9 in.)
Final Drive DID525V8, 114 links
Transmission 6-speed constant mesh
Electrical
Ignition Electronic ignition (Transistorized)
Dimensions and Curb Weight
Warranty
Warranty 12 month unlimited mileage limited warranty
