#Multistrada 1200 Tips & Tricks
A selection of useful tips and video tutorials so you can get the best out of your Multistrada in a few, simple steps.
Chassis / Panniers
Fastening/unfastening side panniers
Use the side panniers to carry all you need on your travels. The Multistrada panniers are fastened and unfastened in just a few steps using the key, allowing you to enjoy your trip in total freedom.
Electronics / Hands free
PIN code function
By activating the PIN CODE function, you can start the bike even if the keys are lost or in case of a malfunctioning system or key.
Key On with passive key or active key with drained battery
Key-on consists of turning on the Hands Free system and all electronic devices in order to be able to switch on the bike.
Active key battery removal
The battery of the Active Key can be easily removed without having to reprogram the keys.
Electronics / Connection
Ducati Multimedia System: iOS Smartphone Bluetooth connection
Listen to your favourite music, receive texts and calls while travelling, or make use of the Multistrada Link App functions.
Ducati Multimedia System: Android Smartphone Bluetooth connection
Ducati Multimedia System: Helmet Headset Bluetooth Connection
If you have a Ducati Communication System, you can connect it via Bluetooth to the Ducati Multimedia System to manage it via your bike and listen to music, receive calls and follow navigational directions. Connecting it is quick and easy, watch this video to discover how.
Ducati Multimedia System: Navigation Bluetooth connection
If you have a Garmin Ducati navigation system, you can connect it via Bluetooth to the Ducati Multimedia System to manage it via your bike. Connecting it is quick and easy.
Electronics / Functionality
Cruise control
Setting your cruising speed is so simple with Ducati Cruise Control.
http://www.ducatiusa.com/bikes/multistr ... L_20160527
