For MORE information and Photos click here: http://www.totalmotorcycle.com/motorcyc ... a-FZ10.htm
![Image](http://cdn-0.totalmotorcycle.com/motorcycles/2017/2017-Yamaha-FZ10a-small.jpg)
![Image](http://cdn-0.totalmotorcycle.com/motorcycles/2017/2017-Yamaha-FZ10c-small.jpg)
2017 Yamaha FZ-10
Welcome To The Next Level...
All-new FZ10 features powerful R1-spec 998cc Crossplane Crankshaft engine, traction control, ABS, D-Mode & YCC-T.
2017 Yamaha FZ-10 http://www.Totalmotorcycle.com Key Features
/// Key Highlights
•R1 / R1S derived engine, chassis & suspension
• Revised engine tuning (combustion chamber, compression, cams, intake valves & intake ports) for strong, linear low & mid-range torque
• Crossplane crankshaft with "fracture split" steel con rods & offset cylinder
• Yamaha's chip controlled throttle (YCC-T), D-Modes (3 modes) & traction control (3 settings)
• Cruise Control
• Compact & lightweight aluminum Deltabox chassis & swingarm
• ABS Brakes
• Upright ride position with slightly sporty forward lean
• LCD instrumentation
• Full LED lighting
Conquer Road
The all-new, aggressively styled FZ-10 is the one you've been waiting for. This flagship model offers serious power and agility thanks to its R1-derived engine, chassis and fully adjustable suspension. Experienced riders will appreciate its comfortable upright riding position, torquey power delivery and corner-carving precision. The FZ-10, guaranteed to provide an emotionally charged riding experience.
/// Power
The latest generation R1 based crossplane engine has been tuned to provide plenty of low to mid-range torque and power. The intake ports and valves, combustion chamber and camshafts have all been newly designed to achieve outstanding "ride-ability" in a wide variety of riding situations.
/// Versatility
Natural ergonomics, cruise and traction control systems plus ABS brakes highlight the versatile positioning of the FZ-10. And with Yamaha's wide variety of genuine accessories, we have your riding style covered. From sport riding to commuting to longer distance adventures, the new FZ-10 is ready to impress.
/// Style
The distinctive exterior style of the FZ-10 is defined by a dynamic mass-forward silhouette with lean yet muscular, athletic lines. A small front cowl, full LED lighting, and exposed engine combine to create the visual expression of spirited performance.
2017 Yamaha FZ-10 - http://www.Totalmotorcycle.com USA Specifications/Technical Details
US MSRP Price: $12,999 USD
Canada MSRP Price: $15,499 CDN
Engine Type 998cc, liquid-cooled DOHC inline 4-cylinder; 16 valves
Bore x Stroke 79.0mm x 50.9mm
Compression Ratio 12.0:1
Fuel Delivery Fuel injection with YCC-T
Ignition TCI: Transistor Controlled Ignition
Transmission 6-speed; wet multiplate assist-and-slipper clutch
Final Drive Chain
Suspension / Front 43mm KYB® inverted fork, fully adjustable; 4.7-in travel
Suspension / Rear KYB® single shock w/piggyback reservoir, fully adjustable; 4.7-in travel
Brakes / Front Dual hydraulic disc, 320mm; ABS
Brakes / Rear Hydraulic disc, 220mm; ABS
Tires / Front 120/70ZR17
Tires / Rear 190/55ZR17
L x W x H 82.5 in x 31.5 in x 43.7 in
Seat Height 32.5 in
Wheelbase 55.1 in
Rake (Caster Angle) 24.0°
Trail 4.0 in
Ground Clearance 5.1 in
Fuel Capacity 4.5 gal
Fuel Economy** 30 mpg
Wet Weight 463 lb
Warranty 1 Year (Limited Factory Warranty)
Color Matte Raven Black; Armor Gray
** Fuel economy estimates are based on US EPA exhaust emission certification data obtained by Yamaha.
Your actual mileage will vary depending on road conditions, how you ride and maintain your vehicle,
accessories, cargo and operator/passenger weight.
*** Wet weight includes the vehicle with all standard equipment and all fluids, including oil, coolant (as
applicable) and a full tank of fuel. It does not include the weight of options or accessories. Wet weight is
useful in making real-world comparisons with other models.
