For MORE information and Photos click here: http://www.totalmotorcycle.com/motorcyc ... na-500.htm
![Image](http://cdn-0.totalmotorcycle.com/motorcycles/2017/2017-Can-Am-Spyder-F3S-Daytona-500a-small.jpg)
2017 Can-Am Spyder F3-S Daytona 500
START YOUR ENGINE...
The boldest and sportiest Can-Am Spyder yet, inspired by racing at one of the greatest tracks in history, inspired by the legendary race track and the previously launched concept vehicle.
Activate the Sport Mode and unleash the fun factor.
SPYDER F3
A low center of gravity and performance-calibrated Vehicle Stability System to provide dynamic handling and great cornering, while ensuring unprecedented control.
2017 Can-Am Spyder F3-S Daytona 500 http://www.Totalmotorcycle.com Key Features
SPYDER F3-S
· Rotax 1330 ACE in-line 3 cylinders, high torque engine
· Vehicle Stability System with ABS, traction control and stability control
· High-performance Brembo braking system
· Gas-charged, aluminum, FOX PODIUM front shocks
· ECO™ mode smart assist
· Passenger pegs
· UFit custom fitting system (rider footpegs and handlebars)
· 6-spoke, machined Deep Black high gloss front wheels
· Sport Mode
· Cruise Control
· Refined front fenders with integrated LED lights
· Black embossed suede seat
ALL SPYDER F3-S FEATURES, PLUS:
· Race-Inspired Colors and Graphics
· Gauge Spoiler
· Super Sport Grill
· Mono Seat Cowl
· Deep Black High Gloss Front Wheels
· Drag bar
TRANSMISSIONS AND COLOR AVAILABLE:
6-speed manual with reverse (SM6)
6-speed semi-automatic with reverse (SE6)
CIRCUIT YELLOW METALLIC
2017 Can-Am Spyder F3-S Daytona 500 - http://www.Totalmotorcycle.com USA Specifications/Technical Details
US MSRP Price: $22,249* USD (*Transport and preparation not included)
Canada MSRP Price: $25,299 CDN (Transport and preparation not included)
ENGINE
Type
Rotax® 1330 ACE™ in-line 3 cylinders, liquid-cooled
with electronic fuel injection and electronic
throttle control
Bore & stroke . . . . . . . . . . . . 3.31 x 3.14 in. (84 x 80 mm)
Power . 115 hp (85.8 kW) @ 7250 RPM
Torque 96 lb-ft. (130.1 Nm) @ 5000 RPM
CHASSIS
Front suspension Double A-arms with anti-roll bar
Front shocks type / Travel Gas-charged FOX† PODIUM† shocks /
5.1 in. (129 mm)
Rear suspension Swing-arm with basic monoshock
Rear shock type / Travel . SACHS† shock absorber / 5.2 in. (132 mm)
Electronic brake
distribution system Foot-operated, hydraulic 3-wheel brake
Front brakes 270 mm discs with Brembo† 4-piston fixed calipers
Rear brake . 270 mm disc, 1-piston floating caliper with
integrated parking brake
Parking brake Electrically actuated
Front tires MC165/55R15 55H
Rear tire . MC225/50R15 76H
Aluminum front rims 6-spoke, Machined Deep Black high gloss,
15 x 5 in. (381 x 127 mm)
Aluminum rear rim . Deep Black, 15 x 7 in. (381 mm x 178 mm)
DIMENSIONS
L x W x H 104 x 58.9 x 43.3 in.
(2,642 x 1,497 x 1,099 mm)
Wheelbase . 67.3 in. (1,709 mm)
Seat height 26.6 in. (675 mm)
Ground clearance . 4.5 in. (115 mm)
Dry weight . 899 lb (408 kg)
Storage capacity . . . . . . . . . 6.5 gal (24.4 L)
Maximum vehicle load . 439 lb (199 kg)
Fuel capacity . 7.1 gal (27 L)
Reserve 1.20 gal (4.5 L) approx.
Fuel type Premium unleaded
FEATURES
Instrumentation
Multi-function LCD segment / analog gauge,
tachometer, odometer, trip & hour meters, gear
position, temperature, engine lights, electronic
fuel gauge, clock
Running lights . 2 halogen headlamps (55/60-W)
Cruise control Electronic
Trims and parts Carbon Black: Rear sprocket wheel, front and rear
shocks springs, exhaust tip and heat shield
SAFETY & SECURITY
SCS . Stability Control System
TCS Traction Control System
ABS . Anti-lock Braking System
DPS™ Dynamic Power Steering
Anti-theft system . Digitally Encoded Security System (D.E.S.S.™)
WARRANTY
Factory 2-year BRP Limited Warranty
with 2-year roadside assistance
Extended B.E.S.T. available from
12 to 36 months
