For MORE information and Photos click here: http://www.totalmotorcycle.com/motorcyc ... ouring.htm
![Image](http://cdn-0.totalmotorcycle.com/motorcycles/2016/2016-Triumph-Rocket-III-Touring1-small.jpg)
![Image](http://cdn-0.totalmotorcycle.com/motorcycles/2016/2016-Triumph-Rocket-III-Touring2-small.jpg)
2016 Triumph Rocket III Touring on http://www.Totalmotorcycle.com
Touring Muscle...
Tour like never before on nothing else.
Extraordinary. Unique. Ultimate. Legendary. Everything you’ve heard about the Triumph Rocket III is true. With sheer force of presence, the Rocket III uses the world’s largest production motorcycle engine to deliver a simply stunning riding experience unmatched on two wheels. The Triumph Rocket III: believe in the unbelievable.
The Rocket III Roadster is a totally unique kind of motorcycle with the most unmistakable presence on two wheels. A true one-off it defies convention and category.
With the world’s biggest production motorcycle engine the latest Rocket III Roadster builds on the huge performance of the original Rocket III but now with even more torque.
The 2.3 litre, three-cylinder engine is designed to be an arm-wrenching thrill to ride, yet easy and unintimidating too, despite its thunderous roar. Its sweet handling chassis, rigid frame and sophisticated suspension gives you the confidence to sweep through corners and change direction with an agility that belies this Roadsters size.
The latest Rocket III features blackened components including radiator cowls, rear mudguard rails, airbox cover, fork protectors, and mirrors giving our Roadster an even more menacing look.
There's nothing else like it out there, not to look at, nor to ride.
2016 Triumph Rocket III Touring http://www.Totalmotorcycle.com Key Features
Rocket III Roadster Standard Equipment
•ABS
•Four-piston Nissin calipers
•Shaft drive
•Unmistakable presence of the World’s largest capacity mass production motorcycle
•2300cc inline three-cylinder engine delivers a staggering 221Nm of torque
•Carefully refined handling characteristics deliver exceptional balance and chassis control with a low centre of gravity
Additional to Rocket III Touring
•ABS
•Back rest pad
•Engine protection bars
•Panniers
•Quick release screen
The Rocket III Touring is available in:
•Phantom Black
•Cranberry Red / Phantom Black
2016 Triumph Rocket III Touring - http://www.Totalmotorcycle.com USA Specifications/Technical Details
US MSRP Price: $17500 USD
Canada MSRP Price: $19500 CDN
Type Liquid-cooled, DOHC, in-line 3-cylinder
Capacity 2294cc
Bore/Stroke 101.6 mm / 94.3 mm
Compression 8.7:1
Max Power EC 106 Hp (78 kW) 6,000 rpm
Max Torque EC 150 FT-lbs (203 Nm) 2,500 rpm
System Multipoint sequential electronic fuel injection with twin butterflies and progressive linkage on primary butterflies
Exhaust Stainless steel 3 into 1 into 2, large volume catalysts in front of chrome-plated silencers
Final drive Shaft
Clutch Wet, multi-plate
Gearbox 5-speed
Frame Tubular steel, twin spine
Swingarm Twin-sided, steel (houses drive shaft)
Front Wheels Cast aluminium alloy 25-spoke 16 x 3.5 in
Rear Wheels Cast aluminium alloy 25-spoke 16 x 5.0 in
Front Tires 150/80 R16
Rear Tires 180/70 R16
Front Suspension Kayaba 43 mm forks. 120 mm travel fully shrouded uppers
Rear Suspension Kayaba chromed spring twin shocks with 5 position adjustable preload, 105 mm rear wheel travel
Brakes Front Twin 320 mm floating discs, Nissin 4-piston fixed calipers, ABS
Brakes Rear Single 316 mm disc, Brembo 2-piston floating caliper, ABS
Instrument Display and Functions Analogue speedometer featuring analogue fuel gauge, scroll button on handlebars, LCD trip computer and clock
Width Handlebars 39.2 in (995 mm)
Height Without Mirror 46.5 in (1182 mm)
Seat Height 28.7 in (730 mm)
Wheelbase 67.1 in (1705 mm)
Rake 32 º
Trail 7.2 in (184mm)
Dry Weight 789 lbs (358 Kg)
Tank Capacity 5.9 US Gallon
Urban * * 27.3 US MPG
Constant Speed 56mph/90kph 43.2 US MPG
Constant Speed 75mph/120kph 34.9 US MPG
